Results 1 to 11 of 11
    staying in heat mode
    HEy I have a split system that seems to be in heat mode all the time. I checked the voltage at the orange wire and there is 24 V. When I deisconnect the orange wire I would expect to hear a hissing sound or something. The big (suction) side pipe is extreemly hot and the other smaller (liquid) side is hot but not as hot. I think the reversing valve is stucks, but how do I know for sure?
    Washington
    Quote Originally Posted by wetbar View Post
    By calling your local professional for guidance.
    ok does anyone else have any usefull comment?
    Mar 2010
    Palm Springs, CA
    There is too much information needed to asses the problem properly.
    Arizona
    Yup, read the rules. NO DIY, sorry.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Yes I have a useful comment - I hate that orange wire - it always gets stucks. My big pipe isn't hot or hissing either. Hate that too.
    Jan 2010
    over here
    nevermind
    If you touch the orange wire to the red, the black or the white wire, it should stop heating.
    At that point, you would be best served by calling a professional to undo the damage that you have done.
    A similar, but more dramatic result can be obtained by touching either the black or the red wire directly to the suction line. THAT is one heck of a way to stop the unit from heating.
    Just an aside. All of the above advice was given in jest. DO NOT attempt any of the things that I have suggested. Doing so may cause personal injury, damage to your system and me to laugh uncontrollably.
    Arizona
    ROFLMAO
    Jan 2010
    over here
    Wow. .......Im gonna have to try the above procedure, first i will bypass the breaker and see how long it cooks first!!!
    Jun 2006
    Hastings, MN
    Did you turn the outside unit upside down for cooling mode?
    Aint Notin Sweeter, Then A Brand New Heater!!!!!!!!!!
