Results 1 to 7 of 7
    May 2009
    Heating effiency of a 15 SEER heat pump?
    Is there a conversion from the SEER rating of a heat pump to a percentage heating efficiency?
    I know that electric resistance heat is 100% efficient and that heat pumps are > 100% efficient.
    How can I determine the heating efficiency of my 15 SEER Trane heat pump?
    Is it approx. 150%?
    Thanks!
    Bill
    Nov 2000
    Upstate, SC
    SEER is the cooling rating and HSPF is the heating rating.
    Washington
    Quote Originally Posted by Bill NC View Post
    Is it approx. 150%?
    Thanks!
    Bill
    Efficiency and operating costs are 2 different animals. This is a chart that my local utility company puts out. Gives you an idea:
    Cal
    COP compares a heat pump to straight resistance. Measured at 2 outdoor temp points, 47 and 17. As Bobby said, the industry has pretty much changed to look at HSPF. That's BTUs per watt averaged over the heating season like SEER. Minimum is 7.7, takes 8.5 to get the tax credit, some 10 as the top point.
    But on COP, at 47 you may be around 3.5 and at 17 probably 2.5 so you can compare to electric heat. Back in the 70s a pump might turn in 2.4 at 47 and 1.3 at 17.
    Jun 2007
    The Twilight Zone
    Get the technical operating data from Trane.
    It should show C.O.P. (Coefficient of Performance) over a range of ambient temps. As ambient temps drop, C.O.P. also drops.
    Goodman has outstanding technical operating data for their heat pumps on their website. For other mfrs, a home owner trying to get tech data is like pulling teeth.
    Take care.
    Dry as a bone Tucson
    comp chart
    Quote Originally Posted by seatonheating View Post
    Thanks for the comp chart. Very informative
    Watchman Nee
