Page 4 of 7 FirstFirst 1234567 LastLast
Results 40 to 52 of 83
  1. #40
    Metro ATL
    Hey Cumulus, how did you make out on this one? Just curious if you had found the issue.
  2. #41
    Nov 2009
    Quote Originally Posted by brooklyntech View Post
    Dont know if this helps-but that float in the gas pump was originally some type of plastic ball (or other tyoe of material), but we had similar issue, and after cutting open a gas pump we found that little ball had melted or warped from the heat of brazin all the line goin into gas pump. I cant remembr if that was on an rthc or rthd? hmmm. I'll have to ask.
    The origional check valve was an issue. I remember attending a warantee meeting when the machine was still in development, and none of us liked the check valve design. I did change one which has the symptom you described. Just make sure the check is seating on the drain cycle by checking temperatures when in the fill & drain modes.
  3. #42
    Jul 2009
    Michigan
    RTHD & RTWD
    Is there any consensus that the RTWD will have all the same issues as the RTHD?
  4. #43
    Nov 2009
    The early issues on the RTHD were resolved, so I would suspect the RTWD would be ok overall.
  5. #44
    Not in Iran
    Quote Originally Posted by graham View Post
    Another thought , you say the gas pump is working . How do you know ? just because the solenoids are alternating does mean its working ,the check valve could be blocked /stuck etc.
    Did you hook up you laptop and run trendview to check "The Heartbeat" this is proof that the gas pump is working .
    is this program the techviev program that u are talking about and also is this the only way to tell if the gas pump is working? how can one tell if the solenoids are leaking by., i hear that that can b a problem as well ., check valve can b an issue thought huh., can the gas pump be isolated to do the repairs?
  6. #45
    Not in Iran
    Talking
    Quote Originally Posted by maxpower View Post
    If you had some contact info in your profile you could receive some more info you could read..
    hey bud u think i can gete an email about this as well ., i am biddibg on this machine and i want to b prepared., thanks`
  7. #46
    MEXICO
    review this bulletin
    RTHD/RTHC
    Gas Pump Solenoid Leak
    Order Number: RLC-SVC12A-EN
  8. #47
    Not in Iran
    Quote Originally Posted by servicetrane View Post
    RTHD/RTHC
    i went to trane.com under lit search., cant find it .,
  9. #48
    I saw the service bulletin about the lines to the liquid level canister being sloped, there was also one that said something about if the insulation fails or falls off or whatever on the liquid pipe to the canister, "rapid and violent boiling" of the refrigerant caused by high ambients outdoors and inside mechanical rooms can throw off the float.
    I pulled out an old float style liquid level sensor recently and upon looking at it, considering that the thing is surrounded by refrigerant and some oil and is not subjected to any force, I don't see how it could ever fail, or stick, or do anything other than what it was designed to do...
    The RTWD has CHHP compressors, which are a different animal than the CHHC compressor you have on an RTHD.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
  10. #49
    MEXICO
    oil prevents a good reading of liquid level sensor in the RTAC units a high level of oil causes many problems including liquid level sensor
  11. #50
    I can see how having excess oil in the evaporator would affect the reading of the liquid level sensor, but what I was talking about was a mechanical failure of the float itself.
  12. #51
    Quote Originally Posted by mlkwal1 View Post
    because the lit number he gave you was a 'Confidential Service Bulletin'
    look for RLC-SVB12A-EN
  13. #52
    Not in Iran
    Thumbs up
    Quote Originally Posted by jayguy View Post
    ok thanks
Tags for this Thread
