    Jun 2001
    Northwest Indiana
    06E Oil pressure lockout_NOT!
    Anyone run into a Carrier 38AKS 028 -601 running the compressor with a net oil 0f 2psig and not tripping the oil saftey?
    This compressor was so noisy I wasnt sure what head to pull first to inspect for damage.
    I decided to condem the compressor all together as their is no way to tell how long it ran without lube.
    Also noticed the resistors on the control module were overheated. I checked acroos the input for the ops and the switch was still closed after 4min of compressor runtime below 5psig.
    If you cant fix it right, try again.
    East of big city prices.
    Oil in the sightglass?
    Jun 2001
    Northwest Indiana
    Quote Originally Posted by thegoodlistener View Post
    A little less than 1/8" "no agitation"
    Jun 2001
    Northwest Indiana
    Split (upper,lower) DX coils. They are both plugged solid! Condensor coil also plugged solid! Return fan belts loose and drive motor pullet open too far with the belts riding low.
    All contributing to this failure, this store stops maintenance 2 yrs ago and wonder why.
    Dec 2009
    Southern US
    We have had several natiional accounts stop maintenance programs in tghe last few years. Some have restarted when their repair costs have become excessive from just the type of issues you found.
    I'm good at making things cold...You can ask my first two wives!
