Results 1 to 10 of 10
    Alabama
    Carrier Chiller Thermistor Number
    Carrier chiller model 30GTN150 serial 0501F60515.
    I need the part number on T2 thermistor for the inlet water temperature sensing. This is the one that mounts with a compression fitting in the inlet on the barrel.
    I have an HH79NZ029 on my truck but I'm not sure if it's the right one. The number is missing on the existing one and the supply house is closed.
    What can I use for a compression fitting in a pinch, the ferrel on the old one will be compressed on the probe?
    Dec 2006
    Middle Tennessee
    it looks like the right one
    dip it in ice water and check the ohms
    there is an ohm/temp chart right there on the panel of that Carrier GT chiller
    all the sensors are the same
    Alabama
    Thanks for the help, that worked.
    East of big city prices.
    5K at 77 degrees. As long as the length is the same.
    Dec 2009
    Fort Worth, Texas
    should be a 30gb660 ! water and refrigerant circuit thermistors should all be the same.
    i think it just a 5k negative coefficient thermistor
    true knowledge exists in knowing that you know nothing.
    keep a lot of them they only last a few weeks!!!!!!!!!
    then you get the error code that says the chw inlet temp is colder than the chw outlet temp
    i think it is error code p97
    Quote Originally Posted by supertek65 View Post
    You got the wrong chiller there Ace, but I know exactly what your talking about.
    May 2008
    Central Pennsylvania
    In a pinch I have used standard BAS strap on type sensors, of the same resistance of course.
    oops!!!!!!!!
    Quote Originally Posted by thegoodlistener View Post
