Results 1 to 13 of 20
    I go into this market this morning and the meat cooler is above temp.
    Climb the ladder and check the pressure on the rack and find someone had reset the EPR valve up from 43 # to 60#!!!
    WHO Twealed that screw???
    Do they just go out of adjustment on their own?
    Was it the atomic mole men?
    Was it a disgruntled employee? (we had one at another store, 100 miles out in the country!!!)
    Apr 2003
    Levittown, PA
    Frown
    Gremlins, I hate those little bastards!
    Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
    new orleans,la
    Red face
    Diceman did it, He Knew you come in .
    koolrite837
    new orleans,la
    Talking
    Hey R12, Diceman was there before you.
    koolrite837
    Talking
    Nobody has tweaked your screw in a long time, except you I mean, that's your problem.
    Hey cockroach, don't bug me! ©
    Florida's space coast
    Put a drop of loc-tite on that screw and in the future you'll be able to see if someone messed with it.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
    Apr 2003
    Levittown, PA
    Dam dice you seem to get blamed for everything around here.
    I was gonna start a thread entitled; "Who Barfed In My Drain Pan???"
    I got to this dairy cooler yesterday and found the drain plugged. It was full o .... "pukey lookin stuff". You know. ..the kinda stuff a goat coughs up after eating too much grass or something.
    Orange County CA
    wait 'till you get to a nice ripe produce wet rack , service deli or dairy case
    Sep 2001
    East Stroudsburg, PA
    That's not a real good idea on an EPR.
    Hazardous to your health, if I'm the one that has to adjust it next time. EPR screws are generally pretty stiff to move to begin with. So, if you're gonna do it, you might not want to own up to it.
    Bob, someone probably tried to adjust it themselves in the store, it's happened to me a few times.
    They think that they can bump the temp "up a little" by turning the screw. Next thing you knows, there you are, on top of a meat cooler.
    Apr 2003
    Levittown, PA
    I use clear nail polish. Especially on unit's in the city and if I think somebody's been screwing with the control adjustments or letting gas out. Most people, even techs won't look for it, but you will know if somebody has removed a cap or turned a adj screw. It also has hardly any tensile strength to bind anything up and chips off easy.
    Just my .02
    Earth
    Check with the Meat cutters, I think you will find Not Me! Did it.
    Or if it's Sporlan (the best), might be time for a KSM.
    Cochrane, AB
    It may be time for a rebuild kit. I recently redid 3 SORITS that were allowing the pressures to build up to 35-45 from the setting of 18#. The temps in those coffin freezers were all over the place. Steady as a rock, now.
