    Nov 2008
    Auckland New Zealand
    Alerton FST alternatives
    Hi all
    Has anybody have or know of a good fst alternative, something like the good old 2650 for ibex?
    FST is not a good look when going through major airports always get the 20 questions.
    Cheers.
    Dec 2006
    What? Who? Where?
    Ordered one of these on Friday:
    http://www.ccontrols.com/basautomation/basportable.htm
    Should work for BACtalk, for Ibex I don't have a clue.
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Nov 2008
    Yip I think that is the one we are looking at getting,
    but there was an issue with it, I think someone said there was a problem with the amount of device's that it could see on a trunk.
    I guess you would have to disconnect the controller off the trunk and do what ever you wanted to do and then reconnect it.
    Is there anything else on the market?
    Dec 2006
    What? Who? Where?
    The issue on device limitation is the load of the RS-485 chip. Full load = 32 1/2 load = 64 1/4 load = 128 1/8 = 256. So depending on the system it should be capable of connecting to a buss with more then 32 controllers.
    All the systems I work with must use less then full load chips as generally we have more then 32 controllers on a buss.
    kontrol out
    "Good" - Jocko
