    Apr 2008
    Tayloer Magarita Machine(Model 340-12) technical support
    I have a taylor magarita machine that product is not thick enough. I have started to adjust the thickness slowly. But I am concern that I may be low on charge(404A) 165#/25# @ 72 degree ambient. Can anyone give me insight. suction line temp @ compressor=46, discharge temp=120, liquid line temp=72.
    Jul 2005
    FLORIDA
    both pressure sound very low on this system leak check and then pull charge and weigh in new charge and you will have your answer even if you dont find a leak, what its hold 1 lb maybe 2
    should be around 200/225 head depending on how clean the condenser is
    I've got a frozen crapachino machine from Taylor and info is hard to get
    once you think you've seen it all
    (THINK AGAIN)
    I would rather work for free than be look upon as a thief!!!!!
    Jan 2005
    Veterans Home Yaphank, NY
    Question Readings make no sense
    Quote Originally Posted by moe663 View Post
    Discharge temp= 311 #
    Suction temp= 95-5#
    LLT= 153#
    RAM Teaching Tomorrows Technicians Today.
    Jul 2002
    NY
    Not enough sugar in the mixture. Look at section 3.2. I know they are different companys but the concept is the same. I ran into where the mixture was to thick and they swore they didn't change anything.
    Not what it use to be
    Jan 2005
    Seek and ye shall find
    Dec 2009
    Southern US
    Talking IDEA
    Send the machine with mix and a case of gold to me and I,ll return when its working.
    I'm good at making things cold...You can ask my first two wives!
