Results 1 to 13 of 19
    Mar 2010
    Trane RTU YCD075
    In all my years in the HVAC world i never thought I would run into a simple low vol. wiring problem but I am baffled. I have a Trane YCD075 roof top unit and am tryin to wire a trane non programmable zone sensor/ tsat to it but do not understand how to wire it to the teminal strip. I tried wiring it to the same terminals the programmable stat was wired to with no prevail. Also the wiring diagram on the door is destroyed... thanks a whole lot trane for putting the schematic on a door that recieves weather damage! Any help on this situation would be great.... THANKS!!!
    Indiana
    i had one like this a few years ago..i dont remember how i wired it but i had to talk to trane ENGINEERS not just tech support. seems the directions they gave with sensor was FUBAR. My advice call trane.
    Oct 2001
    what is the sensor number BAY????? i have a IOM that shows diagrams for 4 of them..06,08,019,022 i will get back later to check
    "when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
    Iowa
    I have the info for the majority of the zsm's but i will need the number off the one you are putting on.
    Bring back rotary phones so we dont have to press 1 to proceed in ENGLISH!!!!
    Delaware
    Look for the micro control book.
    Delaware
    are you trying to replace a zone sensor with a T-stat?
    does that unit have a cti?
    Mar 2010
    the sensor is a baysen108a
    Jun 2006
    New Jersey
    Quote Originally Posted by mafd287 View Post
    You sure......can't seem to find anything close to that. The best I could find was a baysens018a
    Iowa
    New one on me, sorry I dont have the info for that one.
    x---------------83701 p38
    p.6 reference
    don't have a clue where this came from
    Delaware
    Witch board is in the unit Micro or Reliatel?
    Southeastern Pa
    Quote Originally Posted by IRONHILL24 View Post
    I don't have time this morning to research this, but I was under the impression that a YCD unit is a Precedent series, and has Reliatel. That would mean the poster is trying to connect to the same terminal strip along the edge of the boards where he found a conventional stat, and he should instead be using the strip for the trane zone sensor.
    Maybe Jay will find this and correct me if I'm wrong.....
Tags for this Thread
