    Repair vs. replace Carrier AQ38/40RR
    I have an old 6-ton commercial Carrier heat-pump AC system, 38AQ-40RR.
    The evaporator coil just bit the dust. We're looking to replace it, but it's a major operation just to get to the air-handling unit itself due to its location above a ceiling grid. Since we're going in anway, we're thinking ot replacing the whole air-handler unit instead of just the coil. It uses R22.
    * Can we replace just the inside unit with an r410a indoor air handler but still keep the same old rooftop unit?
    Apr 2009
    Replace the whole thing it will be more cost effective in the long run.
    Agawam, Ma
    Replace for sure
    Jersey
    replace it but make sure that they change the 410-aTXV to a R-22 TXV, be sure to have a pro perform the work.
    Life is too short to give a SH*T about the small things, Thing could always be worst!
    Karma is great!
