Results 1 to 13 of 25
    New Hampshire
    Frown Questions on NCM's
    I have just taken over a site and I have to support these things until we can upgrade them to Jaces and then the world will be good. I was hoping some of you might be able to help me out with a few things.
    All of the NCM's are standalone and have a modem hooked up to them. The modems are suppose to dial out whenever there is an alarm present and the point is configured to do so. However only a couple of the buildings actually do this. I have verified all of the settings in the ones that do work and the ones that do not work are the same. The other day I had the customer trip out the boilers to test the alarming and the point went into alarm status and the modem never even attempted to dial.
    Another issue that I am having is that the previous service provider guess who that was, never replaced any of the batteries in the NCMs so everytime there is a power blip the thing needs to be downloaded. When I went to download the device it just went into a constant reboot every 2 min. or so even when it was connected to my PC and it said it was taking the download.
    Any help would be greatly appreciated.
    New Orleans, La.
    It has been a long time since I messed with NCM's. Push the download button and let the NCM force the download. What software are you using in your PC. Have you looked at the DDL files? Do you have all the config files? If you have all the config files for the ASC's your transition to FX Supervisors will be a lot easier. As for as the dial out is concerned, it could be something as simple as the modems loosing their setups.
    Mar 2006
    Quote Originally Posted by ControlsAreCool View Post
    they would do their download over the phone line to a archive OWS. So..dead battery with no modem activity = no download = dead NCM.
    Re: NCM
    I will assume you have a NCM 350.Did you check your Novram in the NCM kinda curious as to what port the modem is assigned to.What type code general with OT or NT use NT when you have a modem assigned to port two . Any error logs in the archive? Are you trying to download the database from your laptop to the NCM? Man better you than me that's all I can say
    GB
    Quote Originally Posted by Cal1 View Post
    GB
    While you're checking the Novram in wncsetup, you also might want to check that the correct modem initialization string is set. Without the correct string the NCM will not be able to dial out.
    If you need to change the modem initialization string, make sure to do a code and data download afterwards.... only during a code download will the new string be send to the NCM.
    New Hampshire
    Some of the NCMs are 300s and the rest are 200s. Nothing like keeping your customer up to speed on the latest tech. I will have to check the modem setups that was going to be my next step.
    Have only had to maintain NCMs so I'm not that up to speed on the operations of them. Is the modem setup lost with the data on a power failure or does that at least stay. Working on many other products for a number of years now I can not believe how difficult it is to download these things.
    Mar 2006
    You have not even got to the fun part yet. First you need to find where the NC is looking for the Archive...then hope to god that its a up to date/clean database with all models and source code for processes when you find it.
    This could get real crappy real fast. Be careful.
    Tennessee
    I am in the same boat kinda. I have a NCM 350 that power supply got wasted. replaced power supply and need to bring db back in. I should have all the tools to do it but not sure which route to take. The PMI is remote and the NCM is dialing out. Doesn't look like a transfer is taking place. Do I hit the hard reset switch to force a download? What do I need to do? Not trying to hijack the thread, just thought it might help OP as well.
    He who asks a question is a fool for five minutes. He who does not ask any questions is a fool forever.
    New Hampshire
    No I was having the same problem. I had to connect to the NCM with WNCSetup and change the archive port from 2 to 3. Make sure as stated earlier that all of the databases are the current, otherwise you are not going to get very far.
    Also make sure your PC is setup with a ncdirect connection.
    As far as I could get by reading the literature. I believe in order for this to work you also have to set the archive node and gate to 1. Someone please correct me if I am wrong.
    Tennessee
    Ok, so I finally got the thing to setup on direct connection. I am using a null cable on port 3 and the tx rx lights are both lit. They will light and go out simultaneously every 45 sec or so. The PMI is continually saying waiting for connection. It will not connect to wncsetup. Any ideas?
    Mar 2006
    You have no .net compiled.
    Tennessee
    net.ddl? I have never attempted to connect to a NCM before. Never had the need. Please treat me like a moron. Hehe. I opened the net.ddl file and it is setup for a dial up connection. Do I need to compile another ddl for direct connect? What am I sposed to do next? TIA.
    Mar 2009
    Several Miles from Sane
    Ohhhh Boy !
    Quote Originally Posted by freddy-b View Post
    The understatement of the week !
    If you can get the NC to recognize your PC that's the first step.
    Guess, the NET.ddl file you are using is ok but you need to get your Global.ddl file straight.
    Make sure that your PC (or Laptop) has the database at the correct rev.
    First decompile (unddl) the archive BUT copy any *.ddl or *.und and *.bas file to another folder (directory), FIRST. If you have no errors (in the *.und files) all you have to do is get the NC to connect and everything else should fall into place.
    Another thing, make sure that you run prepfor to set your path statements on the PC. If it's rev 10 or before it's a dos command rev 11 or above it's a program under the "Metasys" program group.
    On a good day with all the stars in the right position and your Karma in perfect balance and you do everything right this is gonna take you a good hour. On a bad day this could run into a couple of days.
    I honestly hope you're not working with rev 10 or older, that is a PITA !
    "Be careful out there"
    Remember Controls Cause Insanity !
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
