Results 1 to 7 of 7
    May 2005
    need some help on a alco valve
    i cant seem to get ahold of anyone at emerson/alco to help me.
    i have a valve that is like a txv.part # asb-3
    these valves leak freon and i dont know why..i need 3 of these hopefully a new design..
    can anyone help me?
    heres what the sticker on the valve says:
    ASB3
    040193-07
    15603 PH
    Jul 2000
    Guayaquil EC
    I can't find anything like that number on Emerson's (Alco) site.
    But why not just pick a different TEV to suit your application, conditions and capacity?
    May 2005
    i talked to a guy at sporland cause i thought it was one of theres..anyway he told me it was a discontinued valve..its a weird one, came with a polyethelene cap and theres a 1/64 hole in the cap where oil is coming from..its on a filerine chiller..1/4" lines in and out..ive talked to the chiller maker and they had no idea why the valve would leak..and like i said getting someone from also in impossible at this point ayway.
    florida
    That sounds like it's a constant pressure expansion valve I found the A series valves in the johnstone catalog # 198 pg 1286. Or here's a link http://www.johnstonesupply.com/corp/...t_Code=B12-512 I'll bet they could help ya out.
    Educational forums are open.
    May 2005
    thats the SOB..but see that poly cap?? as i said it leaks from under it..
    florida
    Quote Originally Posted by primmers View Post
    LOL yes they will do that sometimes. But I've had good luck with them for the most part. BTW ya cant use to much heat when ya burn one in or it will leak every time.
    May 2005
    im real carefull with fire...ill get ahold of parker tomorrow..thanks man..
