Results 1 to 10 of 10
    May 2008
    Somerset, New Jersey, United States
    Need Help - Staefa Actuator
    Hey,
    Anyone know where I can get information of a Staefa ASU 1D 15US actuator? Even a direct replacement would be good. I have an old friend who is trying to replace these with a Belimo GMB-24-3 and cant get it to work.
    Any help is appreciated!!!
    Apr 2008
    UK
    I don't know about a ASU1D15US, but the replacement for the ASU1D15 is the GEB161.1E 24VAC Modulating (0-10 or 0-20) Rotary 15Nm damper actuator
    The GEB161.1E is physically differentfrom the ASU1D15 and you might find that the ASU1D15 worked on a 0-20V Phase cut signal so a converter might be required. Attached is the datasheet for the ASU1D15.
    If the AS1D15US is a spring return version (I'm thinking maybe thats what the US part is ) then maybe a GMA161.1E is more suited.
    The GMB-24-3 is a 3 point control device (open/close) so not suited to replacing the ASU1D15. The U in the name means it requires an analogue control signal. If it was a AS1D15 it would have been OK
    Hope that helps.
    Don't be a stupid dwarf. It's not big and it's not clever!
    San Jose, CA
    I have no idea about the part #. I used to work on Staefa back in the day. Old Staefa used a 0-20VDC phase chop signal. This was a rectified signal. Todays 0-10VDC od 4-20MA controllers will not work with a controller or actuater that have these signals.
    Here is what we used to convert the signal
    http://www.atkinsonelectronics.com/l...=SignalConvert
    Good Luck.
    DC Metro Area
    There is a way
    If you have a phase cut card - and it sounds like you do - you can pay an arm and a leg to get a phase cut actuater, you can change the card to one that does 0-10vdc on the proportional out puts or you pull a third wire to the device and get one of these ASM2 converters wired in, http://atkinsonelectronics.com/list....=cat&ct=Staefa The last plan is what we do if we don't change the card. Then you can get a 0-10V actuator to work with the phase cut card.
    May 2011
    SWEDEN
    Smile
    Quote Originally Posted by picnik View Post
    Hope that helps.
    Dear sir can you atatch the file (ASU1D15_Modulating_damper_motor_CA1N4633E.pdf ) once more. I'm trying to open it an it doesen't work
    Apr 2008
    UK
    May 2011
    SWEDEN
    Hi
    Thanks for the quick answer.
    But diden't find the ASU1D15. Only the newer siemens.
    Tried to google but
    Nov 2009
    I am pretty sure that Belimo still makes an actuator that has a 0-20 phase cut signal. Simplest would be to just use the phase cut signal as is and wire same.
    Or you could just change out the control system.
    Apr 2008
    UK
    Sorry, I miss read the post as was reading on my phone.
    I'll try and post again
    May 2011
    SWEDEN
    Talking
    That worked
