Results 1 to 11 of 11
Thread: what would you do
02-22-2010, 10:36 AM #1
what would you do
About 3 months ago, a customer contacted us about installing new/used equipment he bought in a store he was opening. He was given a price and had someone else do the install. Last week he called for service on a freezer he brought from old store. On arrival I was told the new freezers were not working. There are 4 freezers-a,b,c,d.All evap coils froze up.All cycle on lpc(wired betweed 1 and n on timer). Nothing hooked to 4 and x on timer (no t stat, lls,temp termation). Only 3 and n went to the cases. Timer c controlled case d and d controled c. All condensing units are r404a and systems are charged with r404a. The 2 txv's i saw are r22 txv's. My question is what would you do with this situation (walk away, run away, kick the owner in the stones, rip it apart and start over, burn everything.) I'm just asking a general question to get the post count up.
02-22-2010, 10:57 AM #2
- Aug 2000
- 749
Kicking in the stones sounds like a pretty good idea!
But I guess I would just shake my head and explain to the customer why he got such a good deal on the install, and quote the work time and material to straighten it out.
(this is the kinda stuff that pisses me off, losing a job to the lowest bidder, now look at it)
02-22-2010, 11:20 AM #3
- Feb 2001
- Anaheim, CA
- 65
Tell him that buying "cheap" always costs more in the long run.
02-22-2010, 12:24 PM #4
point and laugh at the owner until your gut burst open.
02-22-2010, 02:38 PM #5
Been in situations like that and I have a pay as you go policy. I tell them I'll do one job at a time based on T&M, don't know how long or how much it will cost since I not only have to fix it but I have to undo it first, I expect to get paid every two to three days for work done so far and there is not warranty on the parts and job that was existing before I got there.
If I get any hesitation from the customer, I just leave."The American Republic will endure until the day Congress discovers it can bribe the public with the public's own money.
- Alexis de Toqueville, 1835
02-22-2010, 03:25 PM #6
After not awarding you the install, why is he now calling you for the service?
How is this person your customer when you are not the main guys doing all of the work? I would be insulted if I was asked to work on someone elses new install!
02-22-2010, 05:50 PM #7
One thing is certain. If you are fixing it you need to charge extra for working in that cold white stuff on the roof.
02-22-2010, 05:52 PM #8
seeing he found a cheaper installer who basicially new enough to screw it up..
id say it will be t&m since you not only have to undo most of the install..
may as well recover all the refrigerant as there is prob a ton of air in the system...then add proper controls/wiring..
id start on the least fubared system then procede from there..
im guessing the installer may have been a foodservice equipment supplier ???
i used to do alot of refrigeration install in the pgh area...
02-23-2010, 02:25 PM #9
02-23-2010, 02:34 PM #10
seeing how it wasnt ever installed in a workmanship like manner he should
go after the installer- if he can find em-(im sure his check cleared and they are long gone )
or just give him a bid for you to basically start over-and do it correctly
02-23-2010, 02:41 PM #11
