Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 40
  1. #27
    May 2008
    lynchburg V.A.
    around here that vent would be too close to an electric source to pass code but nice work I agree with the 1'' filter it just makes it simple for the h/o also nice to get to go back and charge to clean the coil every 2 years
  2. #28
    Jul 2009
    Nice work!
  3. #29
    Jun 2009
    Ontario, Canada
    Quote Originally Posted by rayr View Post
    Very nice and clean but where is the PURPLE stuff???
    primer only required when the temp is below 10 C/ around 40F
  4. #30
    Apr 2001
    west virginia
    my only complaint would be the brown tape on the wrap, big pet peeve
  5. #31
    NW Arkansas
    They make clear primer for PVC. If inspectors did not require the purple so they could see that primer was used then I did not use the purple primer. Some installers are good at applying the purple primer. Some installers are complete slobs and get it all over the place.
    Signature on hold. Trying to find a real Jefferson quote I like. Others here have bogus Jefferson quotes too.
  6. #32
    athens, georgia
    Quote Originally Posted by openclasspro View Post
    with drier inside though
    agreed... drier inside near e.c.
  7. #33
    Feb 2007
    Corpus Christi, TX
    something everyone points out on my posts is that your diconnect is behind the condensor
  8. #34
    May 2009
    In the Hudson Valley of New York
    Did you have to do it so neat? How are we going to pick it all apart, I am sure some one has already done this for you?
  9. #35
    Poestenkill, NY
    Just curious, where is the electric meter?
    Your work looks great!
  10. #36
    Poestenkill, NY
    Quote Originally Posted by hivacer View Post
    Also The electric would have look alot better with hard conduit, that was probably the electricians, I bought 50' of conduit today for $9, cheaper to buy conduit and wire than it is to use flex and it looks a whole lot better.
    From the looks of it, I bet the electrician would have used Romex. I think our friendly HVAC installer used the MC cable?
    If you use hard conduit that is all good, but then you need to stock THHN - no romex in conduit!
  11. #37
    Jun 2011
    Steeler Country
    If you would have turned the cased coil around, you could have had an even shorter lineset. Possibly a new world record, LOL!
    Very nice. I would be proud to have that in my home.
    I did a R/R on a system recently and we tossed the old 4" filter rack and built the return boot with a 1" filter rack inside. The homeowner was ecstatic. He said the 4" filters cost a fortune and he hated it with a passion.
  12. #38
    Winston-Salem NC
    Quote Originally Posted by stebs View Post
    Looks good, the only thing i dont like in that picture is that condensate pump discharge line appears to be going up over the electrical panel. Also don't like seeing the condensate pump discharge being ziptied to that armorflex conduit, as that flex conduit isnt water tight. Otherwise, it looks great!
    That conduit is classified as liquid tight non-metallic conduit. Only thing not liquid tight are the fittings at the box, and if IIRC, the make water/explosive proof fitting for it also.
    Are you confusing BX/MX/AC for liquid tight non-metallic?
  13. #39
    Winston-Salem NC
    Quote Originally Posted by larobj63 View Post
    Very correct.
    Now, how many HVAC/R techs do you think can explain the meanings of those odd letters on wires?
    Hint, +15, +15, thermoplastic, nylon
