Results 1 to 13 of 40
    Dec 2000
    Auburn, New York
    Heres how we do it
    We do mostlty commercial and industrial, but here is one of our resi jobs we did at a new house last year. All of our jobs look like this.
    This is a RUUD Achiever 90, modulating furnace....They are nice!
    once you think you know everything, you'll never learn another thing!
    why not get the frunace a little higher off the floor, doesn't look like there was a space issue?
    from the pic, is the side of ODU toward gas meter going to be below grade
    all in all looks good
    Dec 2000
    Auburn, New York
    Quote Originally Posted by dandyme View Post
    No need to get the furnace any higher. Dry basement. Its actually all finished now into a bar with a pool table, tile floors, a bathroom, etc.
    Yard is now landscaped and the cement pad I built is above grade more than it needed to be. The pictures are before the homes was even done.
    Feb 2007
    Northern Ontario
    nice
    one of the few that belong on the wall of PRIDE good work
    You miss 100% of the shots you don't take...
    Monmouth Junction-NJ-USA
    Very nice and clean but where is the PURPLE stuff???
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Rochester, MN
    Love the lineset outside!! Wish I done that on mine.
    Jan 2010
    North Huntingdon,Pa
    Quote Originally Posted by mayguy View Post
    with drier inside though
    PA#9377
    Your Satisfaction...Our Goal.
    Dec 2003
    refrigerant piping is nice, drier will be a rust ball in a few years being outside, and there could be a better fitting for the return or some turning vanes in there and I dont like the roll strap on the pvc, I like a strap that is made for it like a j hook or a clevis hanger or a autogrip hanger or snap rod hangers or a trapeze and strut clamps, I know roll strap is easy, just one of my pet peeves. I dont even have a roll on my truck I hate that stuff. Also do you guys always wrap the duct when its in conditioned space? If finished basement I dont think its necessary, not that it will hurt anything. Also The electric would have look alot better with hard conduit, that was probably the electricians, I bought 50' of conduit today for $9, cheaper to buy conduit and wire than it is to use flex and it looks a whole lot better.
    Poestenkill, NY
    Quote Originally Posted by hivacer View Post
    From the looks of it, I bet the electrician would have used Romex. I think our friendly HVAC installer used the MC cable?
    If you use hard conduit that is all good, but then you need to stock THHN - no romex in conduit!
    athens, georgia
    Quote Originally Posted by openclasspro View Post
    agreed... drier inside near e.c.
    Jun 2009
    Alberta, Canada
    Quote Originally Posted by rayr View Post
    primer only required when the temp is below 10 C/ around 40F
    NW Arkansas
    They make clear primer for PVC. If inspectors did not require the purple so they could see that primer was used then I did not use the purple primer. Some installers are good at applying the purple primer. Some installers are complete slobs and get it all over the place.
    Signature on hold. Trying to find a real Jefferson quote I like. Others here have bogus Jefferson quotes too.
    Jul 2009
    Looks good, the only thing i dont like in that picture is that condensate pump discharge line appears to be going up over the electrical panel. Also don't like seeing the condensate pump discharge being ziptied to that armorflex conduit, as that flex conduit isnt water tight. Otherwise, it looks great!
