Thread: Inet Seven Graphics Problem
02-19-2010, 10:23 AM #1
- Jul 2009
- 25
Does anyone know whey a line shows up across my graphics.
All i did was copy them from one computer to another. They are still fine on first computer but the second computer has the line on them...everything is the same. This happened once before but I don't remember how I fixed it. Driving me crazy. Thanks, Noel
02-23-2010, 08:57 AM #2
Abstract/Issue Graphic Lines do not Update
Solution Do you have graphic pages and lines that do not update after an upgrade? There is one primary reason for this:
1.Insufficient Memory: - Check the memory of the PC and verify that it is sufficient for the I/Net Seven Application.
2.Explore into the hard drive C.
3.Go to Properties and look at the physical description of the drive.
The following is the minimum requirements for any PC that is going to run I/Net Seven.
1.Pentium IV (2.500 MHz).
2.1 GB RAM.
3.3 GB of available hard drive space. The Hard Drive should be 120 GB or more.
http://solutionsteam.tac.com/solutio...w.asp?AID=1819"How it can be considered "Open" is beyond me. Calling it "voyeur-ed" would be more accurate." pka LeroyMac, SkyIsBlue, fka Freddy-B, Mongo, IndyBlue
http://threedevilskennel.com/ - not my website.
Versatile Hunting Dog Federation - www.vhdf.org/
02-23-2010, 09:18 AM #3
- Jul 2009
- 25
plenty good on computer
Xeon 3.07 GHz
Mem 3.5 GB of Ram
Hard Drive = 1 TB
06-15-2010, 09:39 AM #4
New Guest
- Mar 2009
- Denton, TX
- 94
I've been having issues loading bitmaps occasionally with the workstations in plant. It is extremely irritating. the workstation all have specs well above Inet requirements.
