    Confused University Student in need of some help (Kitchens/Swimming Pools)
    Hi everyone I've been lurking for the past few weeks but finally decided to register when I ran into this rather large project.
    Before I start I just thought you should know I'm a bit of a dunce when it comes to HVAC systems but really am trying to learn, so go easy on me :P. Anyway, the project.
    I'm currently a quantity surveying student in the UK and have recently been given a group project to design a leisure facility comprimising a restaurant, cafe, bar and any leisure facility/facilities of our choice. The project prior to this used the same floor plan but was an office block, which I designed the ventilation system for, therefore I've been given the short straw of sorting out the ventilation for this one too.
    I was planning on using the same ventilation system as the office block for this project (which used four AHU's supplying 5000m2 of office space, with each AHU supplying one of four wings of the building. I then had VAV boxes in the suspended ceiling with reheat/cool pipes running to them to allow for a lot of control over zone temperatures (this may be the stupidest HVAC system you've ever heard of, but it's surprisingly difficult to find information on commercial systems)).
    However, my group then decided that a half inside half outside swimming pool would be a good leisure facility which, I imagine, will need specialist HVAC equipment.
    To complicate matters further they (the group) want to put a removable structure around the outside half of the pool which allows it to be open in during the 1 day of sunny whether we get in the summer, but closed for the other 364 days of the year. Now this outside removable structure when closed will, again I imagine, require ventilating and dehumidfying.
    The facility also has a commercial kitchen which I assume needs specialist extractors and increased ventilation, which the office block didn't have.
    So, in conclusion, would anyone be able to advise me on what sort of equipment I will require, or even give a book/journal/website I could look at for some idea on swimming pool HVAC equipment? Could anyone advise me on what sort of equipment a commercial kitchen would need? Also, does this whole thing sound a bit financially unfeasable? (there is no set budget but the hypothetical company has a 15 year lease on the building during which they obviously would like to more than break even.)
    Any help would be much appreciated,
    Sam
    P.S. The facility is split into two wings, the pool/sauna/steam room/squash courts/leisure wing and the restaurant/bar wing, would it be best to use two AHUs on the roof each one serving a seperate wing?
    Jun 2008
    Windsor, Ont.
    As far as the pool goes try this link.
    http://www.dry-o-tron.com/dev/html_e...e%208.5x11.pdf
    Washington, DC
    Quote Originally Posted by Burty88 View Post
    Sam
    what kind of pool are you putting in? An above ground with a plastic liner and a tin skirt like in aback yard or are you excavating for a pool. The strutural considerations of the pool should not be over looked. Otherwise this is an extremely complicated project that doen wrong will result in pool odoros and mold blooms that wou;d make a whale salavate. Google dessert aire they have some design guides.
    pool information is out there. lok for poolpak, munters, the above mentioned company and others. i know that munters for one has information out there for design conditions, sizing etc on their site. kitchen usually requireslots of makeup air for hoods, and of course exhaust hoods. also lots of refrigeration, prep tables etc.
    Quote Originally Posted by Pneuma View Post
    Excavating for a pool, roughly 25m x 18m, so it's not small. With about 10m inside and the rest out, but covered.
    Thank you for the link, and to the other contributors for their links, I'm looking into a lot of these websites now. I knew a lot of the information could be found online, it was just a case of knowing where to look. I'm sure I'll be posting in the thread again as soon as I get stuck.
    P.S. those desert aire installation guides are just what I needed, cheers!
Tags for this Thread
