Results 27 to 39 of 42
  1. #27
    Where in SC are you located?
    The building looks like one I'm familiar with in Surfside Beach...just wondering.
    I've noticed the same thing at every condo unit...all the heat pumps get the same way. Must be a pain to have to replace them every 5 or 6 years!
  2. #28
    Hell Hole Swamp
    Originally posted by doggonewild
    I say get rid of the condensor all together. Replace it with water to air!
    You hush...before somebody hears you
    Very close, this one is in Garden City.
  3. #29
    Apr 2003
    Levittown, PA
    Hey swampfox,
    what are the codes like down there? As far as height above sea level goes??
    Shore communities are all different in Jersey. I did one not too long ago in Ocean City, the ho replaced one system and addded a second for the 3rd floor. we needed to built a wodden platform because the condensing units had to be 5' above the back bay flood level to pass code. I think it helps some. Atleast they are above most of the sand blast. Could mean a little extra $$ and save them some if it was possible to relocate them behind the house and off the sand.
    Just a thought.
    Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
  4. #30
    problem
    a ground source heat - pump. igot one down in fla to sell ya cheap.
  5. #31
    Just wondering........................
    ....... specs usually call for special corrosion resistent materials when located near or on coastal properties.
  6. #32
    At least it gives me a ballpark life expectancy for the Heils that i import to Bermuda.
    Ours,start to fall apart after 1 year.I'll post a picture of a 2 yr old carrier chiller next time and you can see that,For a Carrier....it's bad!
  7. #33
    im in pensacola, ive seen that too.bryant makes a unit called coast guard that works well on the beach.
  8. #34
    s.east michigan
    Looks like it's time for another condenser. A Carrier TZA Puron unit would look nice in place of that hiel piece of #!!#.
  9. #35
    Nov 2000
    Coastal Georgia
    The last thing I would put there would be a purmoron unit. In fact I would find the cheapist unit I could for that place.
  10. #36
    Mar 2002
    Richmond, Virginia
    Learn to say R410a. Unless you are brainwashed by Carrier. It's like calling all motor oil Pennzoil. I refuse.
  11. #37
    Nov 2000
    Coastal Georgia
    Doesn't really do much good.
  12. #38
    How would an all copper coil do in those conditions ?
  13. #39
    Hell Hole Swamp
    Good question.... the answer is much better
    The coils seperate due to galvanic corrosion which occurs when 2 dissimilar metals touch, this is rapidly accelerated when salt water is added to the mix.
    good explanation here...
    http://www.mcnallyinstitute.com/CDweb/g-html/g002.htm
