Results 1 to 9 of 9
    FX03 PointMapping Table
    Hi can anyone help me out with a N2 point mapping table for a johnsons FX03.
    Can the digital input 4 on a FX03 be used as a monitoring point for eg. Fan status or overheat status?
    New Castle, DE
    There is no FX03. FX05,07,10,14,16. The point mapping table is built in fx builder and can be set up many different ways.
    Jun 2009
    StL, MO
    I've never seen one, but the documentation says yes.
    UA LU 562
    I managed to source the PRN file
    I managed to organise the prn file for the FX03. When mapping these points on a NAE, certain paramaters can be configured for the FX03 like timers, deadband, PB and limits.
    Near Philly
    Quote Originally Posted by Automation View Post
    What is a FX03? Where did you get a file for it?
    Dec 2006
    230 VAC fan coil controller sold in Europe and Mideast
    The FX03 comes Pre-programmed; all the technician has to do is set a couple of dip switches for the desired control configuration. I sourced the PRN file from the Johnson controls European technical department.
    Near Philly
    Neat, maybe you can manually add BI-4 to the data base and give it shot.
    Dec 2010
    point map table
    Metasys N2 or Bacnet table, which one is your wanted ?
    pls send to me a e-mail ,
    I can send to you .. table and prn file for NAE ..
    eceteknik@yahoo.com
