Results 1 to 12 of 12
    Jan 2010
    Houston, TX
    Clogged Shell and tube exchanger
    We have a Old York chiller with a shell and Tube exchanger. Over the years it has had poor water treatment and is now clogged with rust. Does anyone know how to unclog this mess. We even took the end plates off and could not get it. Help!
    May 2008
    Central Pennsylvania
    Is it a flooded or dx barrel? I'm guessing it is the condenser your having problems with.
    Jan 2010
    Houston, TX
    It is the chilled water side and it is flooded.
    East of big city prices.
    Ok let's go this route. Does the water go thru the tubes or around the tubes?
    Jan 2010
    Houston, TX
    Around it
    Aug 2000
    Under my tree
    Model number would help. If its a DX barrell probably be easier to replace it if its that fouled. Chemical cleaning may help.
    What ends did you take off? The refrigerant circuit heads?
    To much work with too little time!!!!
    Describe what you were able to see when you took the endplates off?
    Jan 2010
    Houston, TX
    Sorry, I just noticed I wrote flooded but it is a DX. When I take the end plates off I see the tubing bundles that a filled with R22. This is the evap.
    May 2008
    Like Abs said DX is hard to clean up. Maybe talk to your chemical treatment co. and see if they can recommend a chemical that will break the debris loose and not do any other damage.
    Virginia
    Do you have the model and serial numbers?
    Nov 2008
    Auckland New Zealand
    Like Chillerguy said it’s probably worth while seeing if the chemical guys have a shock dosage and then follow up dosages to try soften up the scale.
    Water treatment if like insurance you can’t see the benefits till you don’t have it.
    Jan 2010
    New Orleans metro area
    Did a different brand long ago . Isolated the water side and fabbed a temporary recirc loop . we went 15% acid to start and dropped 5% till done .We spent 3 days Went thru some hell but got improvement .The boss even made us use a non rotating hammer drill over a striker plate to impart vibration and supposedly help the process . For the effort and time it would have beeen best to get a new barrel but it wasnt what the boss wanted. Water treatment shouldnt be shortchanged .Good luck !
