    Jan 2006
    Gold Coast, FL
    Carrier 17FA 40K Inspection
    My boss has taken a job to perform a 40K hour inspection on a Carrier 17FA. I have been selected to do this due to my chiller experience. However, my experience is mainly on screws with some cent experience.
    I believe the 40K inspection involves a front end inspection by taking seal, cplg, front housing and transmission cover off and checking thrust, end play and inspect gears for excessive wear. My prob is - what are the specs? I haven't been able to locate any manuals that provide me the info-any ideas.
    They are also wanting us to provide a quote to "rebuild" the comperssor in the event we find a problem. What does this entail? Any constructive comments, suggestions are appreciated.
    Somewhere in the world.
    http://www.commercial.carrier.com/co...2_QRYY,00.html
    If this link works you should be able to download a good amount of detailed information on these machines.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    philadelphia
    your clearances will be slightly different depending on the size compressor... is it a #4 or #5 size compressor?
    Jan 2006
    Gold Coast, FL
    It is a 17FA565B
    philadelphia
    you have a #5 . Look at the last page it will give you the clearances needed. http://www.docs.hvacpartners.com/idc...t/17fa-1so.pdf
