Results 1 to 13 of 14
    Jun 2006
    Pulling gear motor headache
    A leaking auger shaft seal on a Follett Horizon Ice Machine is not a problem, I have done it before, except this time the gear motor would not come off the auger. I called the factory and they sold me a puller. Using the factory puller it pushed the bearing about 5/8 inch in, braking the back of gear box and the gear grease poured out. The puller bolts stripped out of the gear box, but the auger never moved out of the bearing. I called the factory and they told me to cut the auger behind the gear box. Also they told me it’s out of warranty and you will need to buy a new auger, and gear motor. The gear motor is history, but is there some way to save the brass auger?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Imported Photos 00002.jpg
ID:	76572   Click image for larger version.
Name:	Imported Photos 00011.jpg
ID:	76582   Click image for larger version.
Name:	Imported Photos 00013.jpg
    wedged in freezer shelf
    leaky and fused parts usually mean never get a good seal after for auger shafts. Might try a 4" grinder and start going to town
    Tampa, Florida
    just replace entire assembly
    Just replace entire assembly be done with it. Don't bother trying to save that auger, it is grooved or marred I bet & it will still be a thorn in your side.
    Jun 2006
    Quote Originally Posted by badbillr View Post
    That auger and gear motor is very expensive.
    Jun 2006
    This machine is only five years old and auger seal is leaking. I wonder how many guys out there has worked on these and had auger pulling problems?
    Jan 2010
    Arizona
    Never had an auger pulling problem with having done quite a few of them. As long as you pull the pin/cutter head and remove the bolts, the heavy sucker slides right out.
    To actually use a puller with enough force to crack the gearmotor case, wow.
    Bob and Phil are always a great help, when needed.
    Jun 2006
    Quote Originally Posted by few2many View Post
    That what Bob told me to do. Now he wants me to cut the auger between the gearbox and main housing. I'm still working on trying to saving the auger. Some more pic's to come later.
    Jun 2006
    This is how far we got on it and it still won't move. I guess its hacksaw time.
Name:	Imported Photos 00016.jpg
ID:	77482   Click image for larger version.
Name:	Imported Photos 00017.jpg
    Jan 2010
    Arizona
    Torch the hec out of everything around it. Let the heat soak for a while, then get mideval with a hammer or puller. Heat works great, not so sure about warpage on that auger. This has worked well with the stainless follett and IOM augers.
    Also, if the cust is without ice or other ice means, have to consider cost, timeliness, convenience, and get the cust up and running.
    Try a cut-off wheel on a grinder, cut a groove right above the shaft key and along the length of it. either cut right into the keyway or cut mostly in and split with a chisel.
    Jun 2006
    No, that didn't work, but I did get the shaft key out. At least I won't have to buy that part.
Name:	Imported Photos 00028.jpg
ID:	77652   Click image for larger version.
Name:	Imported Photos 00026.jpg
ID:	77662   Click image for larger version.
Name:	Imported Photos 00027.jpg
    st.petersburg,fl
    Lightbulb
    Sure the parts are expensive but so is time... replace the parts and move on to the next nightmare... bet you have enough time vested in this job that you could have already bought the parts and now you have to adjust the bill and cost your company money and the customer... and still wind up with issues with that machine.... Sorry to be so blunt but you have to know when to say when....
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
    Jan 2010
    Arizona
    Perhaps the actual stuck part is the gear and the bearing on the other side of it?
    Jun 2006
    Quote Originally Posted by skpkey9 View Post
    I guess it's a learning experience. At least I know what can go wrong with a simple auger seal repair on one these machines. Follett said, they would give me a discount on the parts since machine is only 5 years old.
