Results 14 to 18 of 18
    Southeastern Pa
    Quote Originally Posted by yellowirenut View Post
    hmm..i am thinking yes carrier does have the manual reset ones...they are much older units..3-5 ton range. Have that wire that wraps around the burners then back to what looks like a black boob..u press the nipple to reset
    The new ones still have that boob, it's in the blower section screwed into the fan housing at about 2:00 o'clock. I see it on units with straight cool and the electric heat packages.
    2 Tim 3:16-17
    AOP Forum Rules:
    East of big city prices.
    The limit in the blower compartment has a manual reset. The rollout does not.
    I know electric heating unit`s have a manual reset at the top of the blower.On the gas heating you might want to double check the manual reset high limit on the 8 and up unit`s TJ series. When even the rollout is auto reset. When you jump up to a twinned heating section like in the E,F,A,and Z series the roll-out switches are manual reset. But on those larger series the limits are auto reset.
    Southeastern Pa
    Quote Originally Posted by thegoodlistener View Post
    I know electric heating unit`s have a manual reset at the top of the blower.On the gas heating you might want to double check the manual reset high limit on the 8 and up unit`s TM series. When even the rollout is auto reset. When you jump up to a twinned heating section like in the E,F,A,and Z series the roll-out switches are manual reset. But on those larger series the limits are auto reset.
    I wanted to keep this focused on units of that size. I think his tech must be thinking of rollouts of another brand.
    2 Tim 3:16-17
    AOP Forum Rules:
    There you go I fixed it.
    Area 51
    Some of those units had a board in them that was effected by RF noise from an outside source. The local Carrier distributor can tell you what to look for on the board to tell if it is one that is effected by RF noise. Had a unit thta was located close to a police radio transmitter tower and it would lock out randomly all the time until the board was changed to an updated version that addressed this problem and it hasn't happened since.
    "Paddle faster, I hear banjo music"
