Results 1 to 8 of 8
    Aug 2009
    MA, Northshore
    Carrier CCN - Lon translator Card
    Does anyone have any information if you can map points back to tridium from the CCN bus using the scrolling marquee? I do not have the CCN software or the carrier service tool at this time.
    Thanks,
    Kula
    Oct 2008
    Negative. Need cview or service tool.
    Nov 2009
    Northern, Kentucky
    If the card was factory installed, you should be able to get the default lon info and default points list for the equipment the card is installed on from your local dealer. The Lon card should have been programmed from the factory when installed. The lon address can be captured when the service pin is pressed. If you want different points mapped then you will need c-view or service tool.
    Feb 2007
    Helena, Montana
    Is this the ComfortLink™ DDC Communicating Controller?
    Oct 2008
    Quote Originally Posted by drj_controls View Post
    I have yet to see a factory installed translator, lon or otherwise, actually configured at the factory.
    Feb 2005
    Where it's dark & damp
    Quote Originally Posted by doodah View Post
    I'll second that. Factory installed and no data factory mapped.
    Apr 2004
    Would the handheld system pilot tool work for this?
    Oct 2008
    Yes, system pilot will work, if you have the stamina. Would be a real butt woopin to do it like that.
