Results 1 to 9 of 9
    Nov 2008
    S.C.
    Whats the proper term?
    You enter a building, the doors slide open- you walk about 16 feet and another set of slideing doors open. The glass room is about 16'x16'. It has supply air enering it from a stainless steel floor grating.
    You are now in the building. You leave the same way. This is a public entrance to a hospital. Would it be a) vestibule-b)air lock-c)anteroom?
    A link with your response would be nice. I say anteroom. the other 2 answers are what two others say.
    Jun 2006
    Charlotte, NC area
    I would call it a vestibule.
    All 3 of these rooms are designed to separate the inner environment from the outer environment and all usually include some type of positive air pressurization to try to keep the environments separated.
    A vestibule is the least effective of these since both door are automatic and can stand open all the time if enough traffic is moving in and out. The amount of air supplied by the HVAC system doesn’t stand a chance against the wind blowing.
    In a hospital an ante room typically separates some sort of isolation room from the public space and has manual doors with closers making it more difficult for both to be open at the same time. They are usually positive to the isolation room and neutral to the corridor or adjacent space.
    An air lock is designed so that only one door can be opened at a time and usually includes a separate HVAC system to completely turn over the air in the space before the 2nd door is opened.
    Sorry, don’t have any links to back this up
    I'd vote A
    Southeastern Pa
    A
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    Air locks will equalize to the pressure of the next door to open.
    Jan 2010
    Vestibule is a passage from a entrance to the interior of a building.
    Jan 2010
    Anteroom an outer room that opens into another room often used as a waiting room.
    Cal
    ISBN: 0-87629-347-x--"HVAC design criteria" by R.H.Rowe III, AIA,PE. describes your space as an isolation and calls it a vestibule . I would prefer to have my winnings deposited in an off shore account please.
    Nov 2008
    S.C.
    thanks, maybe I will keep this to myself. lol
