Results 1 to 13 of 19
    Jun 2009
    Garland, TX
    Red face Walk-In Cooler OOPS
    So, I learned something new today regarding low profile walk-in cooler evaporator coil drain pans (specifically ColdZone).
    This is the style where the fans are on the bottom mounted in the drain pan, sucks air up the bottom and blows it out the sides.
    Well, the screws holding the drain pan in cannot be longer than about 3/4". Because if you use a 1" screw it makes a bad hissing sound as you drive in the screw with your impact driver.
    Luckily another tech was nearby to weld up the hole in the U-Bend and get the thing running again...and luckily the thing was pumped down and off when it happened so only 2 lbs of R22 were lost!
    Surprisingly my boss didn't freak out; his words were "So did you learn something?"
    wedged in freezer shelf
    Did you loose the screw ?
    When I'm taking those screws out I drop the pan a little and send them back in until the pan is ready to go back on.
    If the speed nut is in the cover zip um back in there.
    Oct 2008
    OFFICES IN : ARIZONA - NEVADA - TEXAS
    Smile
    I Know exactly how you felt ..< bbut the good thing iz it only happens once !
    "Rock-n-Roll " Ain't noise pollution..
    Jun 2009
    Garland, TX
    Actually this was a really old unit from 1992 and the screws were so rusted that the shaft was very thin and couldn't get tight anymore, so I installed new screws.
    florida
    Quote Originally Posted by trippintl0 View Post
    You should get a box of non hissing screw's.
    Educational forums are open.
    Jan 2010
    Got to love a man who admits he made a mistake. Had to repair one on a small prep table once. Owner did same thing after cleaning coil up.
    Jan 2010
    Central Florida
    Yea and what sucks is when that usually happens, its late in the day and that's the last screw you put back
    Denver, CO
    LOL....thats why I always use a nut driver working near coils.........now that you posted this in a public forum you will be getting a large bill from the EPA.
    Jan 2010
    Did he say two pounds of vapor ?
    Jan 2005
    steeler nation
    you have a good boss
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    Oct 2009
    Ontario, Canada
    Quote Originally Posted by crackertech View Post
    LMAO!
    May 2008
    The People's Republic of Massachusetts
    I had one of those days where everything goes wrong and I made the same mistake with a unibit into a 5/8 liquid line.
    Sep 2009
    Stumptown,USA
    A guy I know was putting one of those Frame and panel kits on a Trane Intellipak you guessed it. I think it was less than 100 lbs of R-22 but not much less. And I replaced an evaporator in a Trane Voyager that the air balance guy drilled a hole in. Brand new unit. he drilled it right near where the u bend goes back into the coil.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
