Results 1 to 13 of 17
    Antlers Oklahoma
    staging package units
    I was wondering if there is a way to stage 2 15 ton and one 5ton package units. If each unit had several stages could they be connected in a way that they would only kick on in the order needed? Can three units operate off of one tstat? Really one tstat, not hiding others somewhere. I know two can be twinned together. A store owner I know wants something like this. He also wants it to operate all off of one tstat. I need to think about this for awhile but I thought I might get some input from all you hvac genuises.
    Cal
    Jwise, I don't have a clever scheme to share with you ( I could needlessly rattle off many obvious drawbacks/obsticles) but I have to ask...What advantage does (1) enormous CV system/zone offer that (3) seperate systems/zones can't. Is there an objective to be accomplished or is this a "stimulus" type of project/idea.
    Antlers Oklahoma
    Quote Originally Posted by btuhack View Post
    Jwise, I don't have a clever scheme to share with you ( I could needlessly rattle off many obvious drawbacks/obsticles) but I have ask...What advantage does (1) enormous CV system/zone offer that (3) seperate systems/zones can't. Is there an objective to be accomplished or is this a "stimulus" type of project/idea.
    I guess it is a man who wants to part with his money. I really don't understand why he would want 3 units in the first place. Seems to me he woull be better off with 1. Although I can see why with 2 he still has some air conditioning while getting one repaired. I have not bid on this job. I probably won't bid it. I was just wondering if what he was requesting was even possible.
    Cal
    If you propose a normal design with multiple/independent systems, you will provide: a system that can respond to various loads, simplified duct design, low bid, and a satisfied customer. He's not the expert, you are. Make him believe, do it right, and get his money. or, let some other guy do it "his" way and offer to do the corrections in a year or two after the frustration sets in.
    Antlers Oklahoma
    I think this is very sound advice. Thanks for replying. I think I will look at a normal design, stick with what I know, and if he lets me do it, fine. If not that will be fine also. I may be somewhat of a hack (I get better everyday) but I am much less of a hack than most of my competitors.
    Vancouver BC
    Besides think of how interesting it will be to work out a proper solution to this system after someone cobbles together a scheme to operate 3 units from one thermostat. The time spent just thinking this through would easily pay for 3 separate thermostats.
    These Are The Good Old Days
    Sep 2009
    Arnold mo
    Quote Originally Posted by Jwise View Post
    There are controls for everything. On a 3 unit system in a walk-in cooler they had a controller (lion? I think) that was used to stage the units similar to what you mentioned. If you don't find it first or someone else with more knowledge before I do I will post back.
    Sep 2009
    Arnold mo
    Vancouver BC
    How would you even twin 2 units together on one thermostat? Unless you have a fistful of isolation relays you will have tons of unanticipated voltage feedback problems. Every time that I have ever seen multiple units run off a single thermostat, the installer that put it together figured that all he had to do was disable one control transformer and run the signal through to both units after he blew up the first thermostat. Then I get to come unmelt the wiring and add a second thermostat. Of course you can gang the units together with DDC but how is that more sensible than spending $100 for two more thermostats?
    Vancouver BC
    I have a power supply room that has 4-12 ton units. They decided that although everything was working fine that the 4 thermostats weren't sexy enough so they "upgraded" to DDC. Now often I'm called out for service it's because someone has been fiddling with it and the mechanical cooling was operating with the economizers open and it's frozen up or the 2nd stage is operating before the first so there's no condenser fan and it locks out on high pressure. I'm not saying that you can't control the units this way and many do. I'm just saying that sometimes simpler is better.
    Quote Originally Posted by seascott View Post
    I have to agree, with you on this one..
    Antlers Oklahoma
    Quote Originally Posted by tipsrfine View Post
    Thanks for the link tipsrfine. I told the guy I wanted to install one zoned system. He hired someone else who told him he could stage the units together so they kicked on one at a time as they were called for. I think this was entirely out of my capabilities. I hope I don't get called to repair it. (The store owner is getting all of this fancy work and getting Grandair units, if that tells you anything. I think I am glad not to mess with this one.
    Sep 2009
    Arnold mo
    I'm no expert, but the guy that got the job knows controls. You should look into it. The kind of control you would have needed for that job ain't that hard to figure out. I did it on site troubleshooting a similar system my first time running into it due to the manual being there. Big money cust's like that crap. Plus it's the future and beyond........
