Page 1 of 5 12345 LastLast
Results 1 to 13 of 57
    Put in last year or so, nuttin fancy, no manifold with a zillion connections or space age control circuit.
    Hey cockroach, don't bug me!
    Talking Heats this bldg
    Store fronts on bottom, apts up top, about 8 HW zones.
    Guess whats in the "Craft Store," the one with the video camera mounted outside.
    See the oriental nails place on the far left, he owns this bldg, was back changing some zone valves last week.
    What fun that was.
    Jan 2003
    SE Pa
    The King and his "Crown"
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    Ok,I'll start. No swing joint on the gas line? No shut off valve on the gas line? Auto air vent and a compression tank?No isolation valve on the feeder?
    This is fun! Who is next?
    I love my job, but paydays Thursday
    Nov 2001
    BTW, who took the pics?
    Vancouver, British Columbia
    Question Scary
    What's really goin on in that "crafts" joint?
    If a day went by without a problem - there'ld be a problem.
    There is a ball, shut off gas valve right there skip, put your glasses on. And a uion below it, whats up with the swing joint??
    What's you problem with the expansion tank and air bleeder?
    True, you gotta drain most of the system to change the water reg but whatever. That only needs done after years of service and usually is done while other major service is being performed.
    I do have iso valves on the main piping so you can change the pump or access the boiler without draining the rest of the system.........you don't see that very often.
    I'm holding off on the answer as to whats really in the craft store. I mentioned it once long ago, one of my exciting stories about customers.
    I am getting better, I took the pics too.
    8 zones on a double 007??
    i wqould love to see what the flow rates to each zone amount to. what happens when all 8 zones are calling in the dead of winter. low temperature water heading for the boiler!!
    Apr 2001
    san jose,ca.
    Massage parlour for kinky people.
    I think we have a winner!!!
    Apr 2001
    san jose,ca.
    You see, dice on saturday mornings goes in the first place & gets his nails done,then to the second place for a hair do & THEN the third place is a chicken choking room.
