Results 14 to 17 of 17
Thread: electric vs gas
    Indiana
    Quote Originally Posted by Paul Bee View Post
    Have you seen the induction cooktop? It uses eddy currents from a 'Work Coil' to induce heat into the pan itself. No heating elements, it has to be a metal pan though. It is real fast like a microwave. And very efficient.
    how is it at maintaining a low temp? my electric glass top cycles the "burner" off and on to maintain temp..so instead of steady heat you get burst of hot then nothing..pain in the ass Frigidaire
    Sep 2009
    Stumptown,USA
    I don't own one but people who do say it is very good at low temperature control. Go by your local sears and look. This is not new technology. We had these at sears in the early 80's. Sanyo built one for sears and it was state of the art for its time.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    Reading, Pa.
    As afr as the Home owners Geshtapo goes a "aquired" empty beer keg could convienyently (spelling?) hid a 30lb propane tank to hookup from inside the basement or garage. The keg hides it to get it filled, cut a hole in the keg and put the tank inside
    We the willing, led by the unknowing, for the ungratefull, have done so much for so long with so little, we are now qualified to do anything with nothing.
    Refrigeration is all the same weather your making Ice, refrigerating or freezing the product.
    Colorado flatland native
    I have a gas cooktop and an electric convection oven.
    Wolf top is real nice.
    Walter Matthau
