Results 1 to 13 of 17
Thread: electric vs gas
    Indiana
    electric vs gas
    I have a electric stove right now...i really don't like how the cook-top reacts, slow and inconsistent (cycles on and off to maintain setting). May think of going gas..has anyone made the switch? Ive cooked with gas a few times, i know i will have a learning curve, u just seem to have a more even temp and control. Do they make stoves where the oven is electric and the cook-top is gas?
    Winter Haven, FL
    Yes, go to sears.
    You might think about a quartz flat top range. The elements heat up in just a few seconds. Its also super easy to clean. Dont tell my wife, but you dont actually need a pan to cook a piece of meat on the stove....
    If you cook alot or want to cook alot - gas is better because you can control it better. I have all electric only because gas is not available and still can not fry an egg well. I grew up on gas and love gas. Cooks on the Food Network channel use gas stoves. I've never heard of a professional cook use electric!
    Indiana
    as soon as work picks up i am getting a dual fuel stove...i HATE the electric cooktop. I cook dinner about 4 times a week, so yes i do cook a lot
    Quote Originally Posted by BonnieH View Post
    When our Jen-Aire burnt out the last time we went gas. I miss the indoor grille but I have a nice Vermont Casting grille out side and when it gets real cold I have my George Foreman grille. We got a real nice GE range. Five burners on top. It has a griddle which can be removed and the spot used as a regular real big burner. As far at the over goes. It cooks great and the broiler is quicker than electric.
    We too are in an area where there is no natural gas. We hooked up 2- 100 lb propane cyclinders with a switch over regulator. What the heck I'm in the trade!. One cyclinder last us around 9 months.
    Northeast Ohio
    I burn everything if I have to use electric. I even prefer the gas oven over electric works alot better with bread and baked goods and the broiler rocks.
    DEM
    Winter Haven, FL
    Beencool, how much does it cost to fill the 100lb cylinder?
    Does anyone know if I can bury the tank? The homeowner extortion committee forbades propane tanks on privately owned property
    Indiana
    i know it sounds dumb but i do believe my cooktop is effected by other houses power consumption around me...if i start cooking in the afternoon on a cold day it gets hot fast. If i try to boil water for pasta on a hot summer day with everyone running there AC it seems to take forever. Until i moved here i never seen a cooktop cycle the coil on and off to maintain temp, it is a glasstop,
    Quote Originally Posted by Joe Harper View Post
    It costs around $55. The price goes up and down like gasoline.
    Probably they don't let you have these type of tanks in Florida because of the hurricanes.
    You can get residential in ground propane tanks but I would think it wouldn't be cost effective for just cooking. Up here there are inground tanks in some residences but they also have gas heat and a gas dryer and water heater. We are prohibited from having electric heat in a residence.
    Chicago land area 60181
    Really that’s strange I have lived in two places that were all electric. Didn’t see any problems, we were given a lower rate because you were all electric. Do you know why they don’t allow electric heat?
    Myrtle Beach, SC
    I am Soooo glad I live in a neighborhood with no HOA. Soooo glad.
    Remember, Air Conditioning begins with AIR.
    Winter Haven, FL
    Quote Originally Posted by Kevin O'Neill View Post
    Yea, the affluent neighborhood is allowed to have tanks, for thier pool heaters, but us poor schmuks are not. Its the same association too.
    Sep 2009
    Stumptown,USA
    Have you seen the induction cooktop? It uses eddy currents from a 'Work Coil' to induce heat into the pan itself. No heating elements, it has to be a metal pan though. It is real fast like a microwave. And very efficient.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
