    oil analysis for Mcquay Frame 4 screw compressor
    dear friends
    Iwant to make oil analysis for Mcquay Frame4 series compressor, oil type is mobil eal 68 we can make it at Mobil laboratory but I need to know reference value for frame 4 compressor (max.Total acidnumber, max. contamination level, max. humidity level, max. copper- aluminium- iron element level , etc..)
    if somebody help me it would be highly appreciated
    thanks
    Rockhill South Carolina
    call the factory in staunton VA
    tidewater, va
    you could go that route or if you have an aireco or united refrigeration near by you could use National Refrigerants. They have a top-notch program
    r404a
    I love it. I have had more work from people trying out oils that were supposed to be exactly like what the factory supplies.
    Spend the extra $ and get the factory supplied and tested oil.
    Tight is tight, Too tight is broke.
