    Oct 2009
    New to AX custom programming
    I think im missing something with the "greater than" custom block in the FX60. Where can I set the differential for it? I want to enable an input if the OA-T is greater than 65 degrees but I would also like to but a differential in there.
    Use the Tstat block
    There's a lot to know.
    Jun 2009
    StL, MO
    You can't. Use the Tstat item in the HVAC section. Note that the differential is centered about the set point.
    UA LU 562
    Beat you by 1 minute
    Oct 2009
    nice thanks for the help
    Nov 2007
    Phoenix, AZ
    Program
    Quote Originally Posted by Igotworms View Post
    Igotworms
    You won't find what you are looking for in kitcontol. You have to write one yourself. Email me and I'll send you what you need.
    GregF
