Results 1 to 10 of 10
    Southeast, GA / Jacksonville, FL
    Head pressure control
    Need a head pressure control for a trane TCD120C300AA.
    Also if anybody knows, what compressors come in this unit, because i discovered after i installed one, that there were two different sized compressors installed in this unit.
    Sep 2006
    Ohio
    I would use a Johnson Controls / Penn Fan Cycling Control
    Southern California
    navyhydronics, check you email.
    SouthEastern Virginia
    ICM 325
    It might get loud!
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by navyhydronics View Post
    install a P-66 Johnson controller on it
    Central New York
    I agree P-66 all the way.
    Apr 2006
    mechanical room
    i thought that trane rtu was good down to 0'F, no ?
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by coolerinfrederick View Post
    your right, they do have ambient sensors, which will control the o.d. motor/s
    but they don't work off of pressure
    New Jersey
    Does this unit have econimizers? Also coolerinfrederick is correct, this unit is ok to run mechanical cooling down to 0 degrees ambient without head pressure control.
    Sorry fellas but the condenser motors in this unit will not tolerate the P-66. Now the P-266 may be a different story. The ICM-325 is less expensive, has a hard start feature, and is suitable for sleeve bearing motor. The P-66 needs an open ball bearing motor which costs a fortune.
    It might get loud!
