Results 1 to 10 of 10
Thread: Head pressure control
02-03-2010, 08:03 PM #1
Need a head pressure control for a trane TCD120C300AA.
Also if anybody knows, what compressors come in this unit, because i discovered after i installed one, that there were two different sized compressors installed in this unit.
02-04-2010, 07:41 PM #2
- Sep 2006
- Ohio
- 347
I would use a Johnson Controls / Penn Fan Cycling Control
02-04-2010, 11:09 PM #3
- Dec 2005
- Southern California
- 76
navyhydronics, check you email.
02-10-2010, 10:16 PM #4
ICM 325
It might get loud!
02-11-2010, 07:36 AM #5
Banned
- Dec 2006
- Middle Tennessee
- 11,347
02-11-2010, 06:15 PM #6
- Dec 2004
- Central New York
- 70
I agree P-66 all the way.
02-11-2010, 10:32 PM #7
- Apr 2006
- mechanical room
- 1,212
i thought that trane rtu was good down to 0'F, no ?
02-12-2010, 06:15 AM #8
Banned
- Dec 2006
- Middle Tennessee
- 11,347
02-12-2010, 04:54 PM #9
- Nov 2006
- New Jersey
- 78
Does this unit have econimizers? Also coolerinfrederick is correct, this unit is ok to run mechanical cooling down to 0 degrees ambient without head pressure control.
02-12-2010, 10:14 PM #10
Sorry fellas but the condenser motors in this unit will not tolerate the P-66. Now the P-266 may be a different story. The ICM-325 is less expensive, has a hard start feature, and is suitable for sleeve bearing motor. The P-66 needs an open ball bearing motor which costs a fortune.
It might get loud!
