Results 1 to 13 of 16
    Jul 2003
    lvl ky
    Hmm
    Hi, my 91 cherokee 4.0 h.o. cranks at least 10 times before starting, hot or cold, changed plugs, filters, all the usual tune up stuff, still have the same problem, anybody got one with same trouble?, anybody know how to fix it? Oh yeah, a/c works fine (haha).
    NJ
    Got exact same year you do know u gotta start it with brake pushed down?
    thehumid1-------I live in NJ, a state where it's free to come in but you have to pay to leave!
    02 sensor maybe?
    Hey cockroach, don't bug me!
    Colorado flatland native
    Fuel pump leaking back?
    Walter Matthau
    Cincinnati
    With a name like gmac why are you driving a Jeep? You should be in a Blazer.
    That's a classic Crysler/Jeep problem. My Dodge Ram did the same thing. I think sometimes the fuel drains back like Spotts said.
    Jul 2002
    NY
    Just shoot the damn thing and put it out of it's worries.
    Not what it use to be
    Apr 2003
    south texas
    i've got a 2000 jeep laredo , it does the same thing. had the fuel pump changed but it didn't help any. also plugs and filter. can't give any advice on fixing . if you find out what it is let me know.i got the same engine as you do , i think.
    chicago suburbs
    sounds like a leaking fuel regulator.
    FILL OUT YOUR PROFILE!!
    Jul 2002
    hamilton ont can
    first: use only hi grade gas. it will start better and perform much better. mileage versus dollars is about the same. second: turn ign to on and wait for fuel pump and anti lock brake pump to stop (if equiped), set em brake to shut off running lights, shut off hvac. now start
    also under the coil is an ign module which may be source of problem
    i had a 90 with 350,000 kms on it when i sold it.it is still on the road
    Janesville WI
    Talking
    Go ask the Chief and if that dont work go to a different tribe
    Apr 2001
    Arkansas
    Not related to your problem,but today I delivered a condenser to job site in my old 79 J-10. Siding installer wanted to hook up back bumpers and pull. He had a Blazer with a 4cyl. My J-10 has a 360v-8. I had to look back to see if he was still there.LOL He wasn't so smug when I got thru dragging him around the house. Most fun I've had in a while on the job site.
    "FIGHT CRIME: SHOOT BACK"
    test the fuel pump leak down with a fuel presure guage it should'nt drop more than 10-15psi after the fuel pump stops when just turning ign on if it does most likely ck valve in fuel pump bad
    Cincinnati
    Take it to the nearest cliff and push it off then go buy a Chevy.
