Results 1 to 13 of 16
    how many btu's do i need for 1400 square feet
    i live in phila pa, on a slab with 1400 square feet,there are 11 supply vents in the home and the attic is well insulated,about 20 inches of blown in fiberglass how many btu's would be the proper amount for my house,im getting 3 quotes,one says 70000,the other 80 and the other 90,would chose a 2 speed variable furnace,thanks,im thinking 70 is too small am i wrong
    Apr 2004
    MN
    Not nearly enough info. We need window/door info and orientation. Attic insulation, wall cavity insulation values, how many people, attic info etc. Then, we would plug all of this into a load calc. program and give you your answer after we received payment for our time. Or, you could buy the one time use load calc program listed in the quick links at the top of this page called hvac-calc. and do it yourself for no hourly charge.
    Better still, ask your contractors which one of them performed a load calc and go with that one.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Apr 2008
    Northwest Arkansas via Chicago Area via Straight Up from There on Lake Superior
    Quote Originally Posted by salv97 View Post
    Like Doc says, you need a Manual J calc. But anecdotally, I have a house 2.5 time that big with a 100,000 Btu furnace that I think is too big. It's not a super new green house either. I am guessing that most of the time we are running well below 60,000 Btu. We do get 0-10 F a few times and there is no problem heating with the furnace. Now I'm not in Phila but that number would inspire me to look a lot closer at both the house envelope and the HVAC needs. If you listen to the pros here they tell you that the right sized unit should run a lot when close to design temp outside. I find that the more it runs the evener the temps around the house.
    A load calc will tell you how many BTUss your house need HVAC Calc.
    Are you supplies in the slab?
    In philly, doubt you need a 70,000, let alone a 80 or 90. Unless the supplies are in the slab.
    why does it matter if the supplies are in the slab
    They loss heat to the ground.
    how much heat 10 percent,20,or 10000 btu's or 20
    That depends on run length and size. And the temp of the air from the furnace.
    So yours are in the slab then, huh.
    Washington
    Wow, this screams of a homeowner trying to purchase their own unit.
    the house runs 60 feet long and is 24 feet wide,if you had to guess,thanks
    Quote Originally Posted by seatonheating View Post
    Hard to tell.
    Do you remember that other thread. Where the contractor sized furnace is sized right for the house. But, the ducts in the slab are losing too much heat to the ground(guess he forgot to include them in the heat loss).
    That OP should have been here asking these kind of questions.
    Not sure anymore. But, I think HAVC Calc has allowances for slab duct.
    You might want to use it. I put a link to it in post #4. Its worth the 49 dollar fee. if your contractors won't do a load calc.
    I'd rather pay 49 bucks to do my own load calc. then to get a furnace too small that doesn't heat the house. Or one too big that trips out on its safeties and can't heat my house.
    Newer furnaces NEED to move a lot more air then the older ones did.
    i have a 114 btu furnace now and thats too big, 60 or 70 btu might be too small,so it could be either 80 or 90 how does that sound,it cant be perfect
