Results 1 to 13 of 21
    Jun 2008
    Windsor, Ont.
    Free Cooling - Refrigerant Migration
    Just finished an 8 hour experiment at customer's request to see if we could get free cooling from their existing arrangement. I had read up on the subject but never had the opportunity to try it and I was surprised by the outcome.
    Customer has large chiller room with 5 - 2000 ton YK's and 1-1000 ton YK. Upon arrival 1000 ton chiller running at no production winter load of 60%. Forced flow over multiple towers to drive condenser water temperature to low 40's and turned off chiller. Opened valves (chilled and condenser) on 2 idle 2000 ton machines, vanes and hotgas valves were manually driven 100% open and monitored operation. Condenser water continued to fall to 37 (28 ambient today) and chilled loop temp maintained 40f all day long, no tower fans and the same amount of pumps running.
    Anybody else ever encounter this type of cooling just utilizing natural convection from refrigerant flow to condenser from evaporator and how much capacity were you able to attain? Quick calculations come to about 400 tons of free cooling and a power reduction of about 430 KW/hr.
    Once the test was complete the owner wanted the chiller put back online, YK's never cease to amaze me. Started and ran with 38 entering tower water and didn't make any fuss.
    The link shows in theory what we manged to accomplish with standard factory equipment.
    http://tristate.apogee.net/cool/ccfr.asp
    Dec 2008
    Dixiana, AL
    Worked with free cooling on 2 or 3 occasions. Most notably, got 1300 tons out of an idle 4000 TR machine - pretty cool what you can do without technology or moving parts.
    p.s. That's a pretty ugly wheel you got there.....
    Jun 2008
    Windsor, Ont.
    Quote Originally Posted by klove View Post
    Out of curiousity was your 4000 TR machine equipped for free cooling with a equalizer line from top of the evap to the top of the condenser? I feel we have more capacity available here but wonder if we're limited by the volume we can get through a 3 inch hot gas line and the compessor wheel.
    As far as the ugly wheel goes 120 degree tower water can kill a YK, especially without surge protection.
    i have only encountered free cooling machines that were designed to be free cooling machines...they have valves that open automatically when in free cooling mode. you would get about 40% of machine rated capacity.
    the only concern that i would have with your "more natural" set up is somebody make sure that you have your evaporator flow! we have had a "non free cooling" machine freeze up and bust a bunch of evaporator tubes when someone turned on the condensor pumps (closed loop glycol) without turning on the chiller in very cold weather...they estimated that they lost about 20,000 gallons of water through the rupture disk before anybody noticed.
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by nyrb View Post
    All of the machines that we actually left running in a free-cooling mode were designed and set up as such, with associated controls and full flow vent lines and valves. I've also shown some customers that it can be done by simply doing it the same way that you did. They each and every one were thoroughly impressed - not enough to spend a truckload of money to retrofit, but impressed none-the-less.
    The South
    Have that where I'm at,along with heat exchangers.
    The current way it's staged now per the engineer, is the free cooling (through the chillers) is used within about a 5 deg band based on OD temp and load, then if OD drops lower or load grows then its all on the heat exchangers.
    This is the first place I have seen utilising both of these, and this is the first winter for it (new facility).
    So far it's been good, with some tweaks.
    GO DAWGS!
    North Florida/South Georgia
    Cool Website
    Don't want to get too far off topic but that link is a pretty cool website.
    All my leon freaked out!
    Ontario, Canada
    Quote Originally Posted by jayguy View Post
    I totally agree on that point because if you had a power failure or chiller trip on overloads or fuses you would freeze up your chiller barrel for sure.
    Aug 2009
    Jurupa Valley, CA
    I have a plant with 2 1200 YK's, without the free cooling vent line. I run them in make-shift free cooling some nights (shut down chiller, and open vanes and hot gas bypass), and am able to achieve about a 5 deg approach between Condensing Water supply, and Chilled Water Supply up to about 20% of the chiller's capacity. The savings, I find, are minimal, as the biggest load under these conditions are the condensing water pumps, and tower fans, regardless of whether the chiller is running or not. I'd be able to save a lot more if I could cool the chilled water directly with the outside air, and just shut down the towers entirely. It's nice to keep the runtime down on the chillers though, so there is at least some minimal savings there.
    Jan 2015
    We are currently doing this on our YK's. They are single pass machines with no hot gas by-pass. Vanes are manual opened at 100%. What seemed to be the best flow ratios between evap and cond flow during free cooling? We have 4 chillers/2 pair as they are piped in series. I believe you should use as much condenser flow as needed to have the least amount of delta in condenser water across the bank, so that way you are not providing the 2nd chillers in the series with 2-3 degree warmer condenser water, sound right? Any suggestions are appreciated as this is our first year at trying this.
    Jun 2008
    Windsor, Ont.
    When I did it I left the flow rates alone, my machines are paralleled with 3 pass Evap's. I was running roughly 2400 GPM Evap and 6000 GPM Cond. Leaving chilled water temp was less than 1 degree above entering condenser water.
    Jan 2015
    We are at the disadvantage of only being one-pass. We are trying to utilize a by-pass valve we have between the supply chw and return, that is used to maintain chiller DP during regular chiller operation, using it to kind of simulate a multi-pass. Did any of you guys add any additional refrigerant to help with the refrigerant migration?
    Aug 2009
    Jurupa Valley, CA
    Adding refrigerant is unlikely to have an significant positive results, and certainly not offset the negative results during normal operation. This form of free cooling is dependent on natural circulation caused by a difference in pressure between evap and cond. The lower the difference, the lower the flow of refrigerant. It is self regulating in this regard. It will 'just work', until it doesn't. Then you will observe rising chilled water temperatures, deviating away from condensing water temperatures - this is a sign that load has exceeded what your system can do 'for free'.
    The fact that your chiller is single pass really shouldn't make much of a difference. The refrigerant flow is so low that pressure will be pretty stable across the evaporator, meaning saturation temp will be relatively stable, regardless of how many passes you have.
