Results 1 to 13 of 17
    D/FW
    trane rtaa latch fault
    anyboby know what causes a latch fault alarm on these machines? there is no info in iom manual about them.
    Oct 2005
    you dont have the correct manual
    The RTAA IOM does describe the latched faults, but it is not in the form of a single page chart. The IOM I'm looking at starts describing diagnostics on Page 93. There are CMR latching faults (Circuit Manual Reset) and MMR (Machine Manual Reset). Does the chiller have a CLD (Clear Language Display) on it? If it does you can see the fault under the Diagnostics menu.
    You can get the IOM at the Trane website.
    D/FW
    the display says "latch fault" manual reset required. I understand that, but there is no description in the iom as to what caused the shutdown. thanks for the replies.
    There is more than one kind of latched fault. The active and historic (ones that have cleared) faults are viewable under Diagnostics. The IOM will also explain how to navigate through the display.
    Quote Originally Posted by chuz View Post
    you need to press "NEXT"
    Nov 2007
    I am unsure myself
    Quote Originally Posted by jayguy View Post
    Haha thats exactly what I was thinking
    The Great country of Texas
    Quote Originally Posted by mustardman View Post
    Maybe he needs "previous"
    "I'm from Texas, what country are you from?"
    Oct 2006
    Central Texas
    The IOM is only going to explain the different latching faults. The machine is going to give the fault. Read the caption & follow what it says.
    Sic Semper Tyrannis.
    Quote Originally Posted by stickerhead View Post
    Now i'm confused!
    "Dying aint much, its living thats hard." (Josey Whales)
    Jan 2005
    Houston TX
    One Other Trane Of Thought
    Or maybe he needs to press "any key" to continue and can't find "any ke....-GEO
    Ontario, Canada
    loose sensor connections at board is a latch fault we had last week on a RTAA125
    Nov 2008
    Kentucky
    IOM
    Here is a copy of the older style RTAAs
