Results 1 to 13 of 21
Thread: leaky evap coil
    morrison, illinois
    leaky evap coil
    has anyone ever submerged a coil in water to look for leak. i removed the coil from plenum, filled with 320 pounds nitrogen. 2 days later had 300 pounds. then submerged in water and 2 days later have small air bubble pop up about onnce every 1 to 2 minutes. dont know if its a tiny leak or what, any suggestions would be helpfull, been in the business 21 years and never tried this.
    East of big city prices.
    Probably the best way to visually see a leak works for the guy that fixes my flats.
    Jun 2009
    Bakersfield, Ca
    Quote Originally Posted by workhc View Post
    Damn, that's a tiny leak. Interesting method for leak detection too. Seems like it should work pretty well.
    redlands, ca
    Too often, air will get trapped in between the fins and "bubble up" over time. The past few years we have had a lot of success using the yellow dye.
    morrison, illinois
    Quote Originally Posted by airredlands View Post
    now been 3 days and small bubble keeps popping up in nsame location
    Aug 2008
    I have checked for leaks in coils for years by doing this just last summer found a leak in acoil by putting it in my swimming pool. You are right about the bubbles but after three days if the bubble keeps comming from the same location then it is a leak.
    morrison, illinois
    Quote Originally Posted by mike robinson View Post
    thought so, have searched entire system replacing shraders, no oil on condenser coil, valve caps tight,solder joints good. in your opinion filling coil with 320 pounds and have it drop 20 pounds in 2 days is too much, but was not sure about 1 bubble every minute or two. thanks for info, much appreciated
    Tallahassee, FL
    I love Spectroline's Dye kit for leaks like these. You can find ALL small leaks in a system quickly and accurately and also the dye is always in there helping you with any future leaks.
    Dec 2000
    phoenix, arizona
    Smile
    have done that a few times. Insert a small flat blat blade screw driver next to where the bubble come out, wiggle it a little, if in fact there is a leak, you will see large bubble.
    Decide what you want, decide what you are willing to exchange for it. Establish your priorities and go to work." H.L. Hunt
    "In order that people may be happy in their work, these three things are needed: They must be fit for it. They must not do too much of it. And they must have a sense of success in it." John uskin
    Jan 2010
    over here
    I have heard that some maufacturers dont want the dye used with the r410a???
    Tallahassee, FL
    Quote Originally Posted by JJDH View Post
    The dye I use is approved for POE oil
    morrison, illinois
    Quote Originally Posted by amasuperbike View Post
    do you need a special light to see the dye
    Tallahassee, FL
    Yes, The light, glasses, injection hose, handle and 2 cartridges of the universal/POE dye comes in a nice kit. Well worth the investment. Much easier than dunking them in the pool!
