Results 1 to 9 of 9
    May 2008
    Central Pennsylvania
    YK design E oil sump heater
    Hi all,
    I have a YK design E that has developed a leak at the oil sump heater. I have 160.49-RP4 but I do not see the heater listed. I got p/n 025-32918 off the heater. My question is how does the heater seal? Does it have an oring or just the threads. Thank you.
    Oct 2008
    OFFICES IN : ARIZONA - NEVADA - TEXAS
    Use a rubber groment from harbor frieght . Then threads won't matter ..
    "Rock-n-Roll " Ain't noise pollution..
    Somewhere in the world.
    Style is a HD oil sump this should be the o-ring part # 028-12961-010 its in 160-49-RP-5 parts IOM
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    May 2008
    Thanks 56' I thought it was probably an oring. Any chance you have 160-49-RP-5 on pdf?
    Check your mail I sent it.
    May 2008
    Thanks to all who replied to me on here and through email. Have you guys found that these orings start to leak when the power has been shut down to the chiller / oil heater for an extended period of time?
    I would give that a big yes.
    May 2008
    10-4, my thoughts exactly
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by york56 View Post
    And I would agree...
