Results 14 to 25 of 25
Thread: Carrier 30gxn
    Nov 2009
    ewt 60 lwt 60 setpoint 44 didnt have to change config
    30gxn090--641sr comfort link
    East of big city prices.
    I would go thru the configuration of the unit and cross it with a manual.
    Nov 2009
    I did this twice today
    What was the CTPT? Is there some sort of time schedule running ?
    Nov 2009
    ctpt '44' and no time schedual
    Did you cycle power on the machine ? Were there any compressors disabled in the service config? It sounds like there is something really wrong or there is something so simple it sucks.
    With everything your telling me I am wanting to say it should take off and run.
    Nov 2009
    Compressors not disabled. Thats what i thought it should run according what i'm looking at but it won't. It might be something simple or i'm over looking, but i've been over this machine tooooo many times today. A fresh start in the morning. According to the navigator info it should run. oh i did cycle power a few times
    What was the outcome on this job? When you cycled power did all the boards go un-powered or just a few ?
    Ontario, Canada
    Quote Originally Posted by Dave_87 View Post
    Hi Dave , I have a customer with one of these and the confort link should have a history of faults section that you can read .The panel cover only has a few fault codes you really need the full paper manual to find all the code listings . When you cycle the power are you waiting at least the minimum one minute before turing it back on?
    Nov 2009
    Sorry it took so long to answer back. Since carrier made their new change its hard to get good tech support. After going thru all configs, they agreed the unit showed to be running. So i had Carrier come down and reinstalled newer software to MBB. The unit came up and ran. Thought all my problems were solved----not. But after installing new software we noticed B circuit had a discharge sensor reading wrong. Ordered a sensor. two days later the chiller wouldn't shut down at setpoint everytime, going out on freeze protection alarm. If it did shut down normal it would not come back on. Only thing i noticed was the EWT and the LWT sensors not reading the same by 1*. Called carrier they didn't get back with me. So i changed those sensors and discharge sensor. Chiller is running great now. I never seen a seen sensor as it got colder the more it read wrong. Learned alot on this one. Oh i did call Carrier and told them what i found. I thought it was a good one for anyones notes.
    Thanks for everyone's input
    reminds me of a 30gx i posted about awhile back , processor scrambling oil differential readings , electronics are great , but have to be made well , unfortunately i see the opposite happening , regards stan
    Keep it simple to keep it cool!
    So your control voltage is coming from a seperate source. I should have asked for the serial number . Well it`s always better to get the software upgrade anyway.
