Results 1 to 13 of 28
    Oct 2009
    Programing Honeywell Vision PRO 8000?
    Model is TH832OU1008. I believe what the current program is if the room temp is -2 degrees below the set room temp the EMER heat strips kick in to bring up heat up quickly. Can this be changed? How? Can this be set to say 10 degrees difference between room temp & set temp before EMER heat strips kick in with this thermostat? ( Rheem PRQL-024JEZ W/ RHLL-HM2417JA)
    Can't do that. Add an outdoor sensor and lock off strips in milder weather.
    Wow. I sure wouldn't want my place to drop from 70 to 60 before my aux heat came on. That isn't comfortable.
    Tallahassee, FL
    FYI..... call them heat strips or AUX heaters
    EMER heat is another setting that turns off the heat pump and heats with only strips.
    BaldLoonie gave a great suggestion. The only problem is...a few degrees below 40 (outdoor) and it allows the strips again. You cant select a colder setting than 40 with your thermostat. But you will still benefit from the sensor...its just I was disapointed that it only went to 40.
    Quote Originally Posted by amasuperbike View Post
    Get an IAQ thermostat and you can set it as low as 5F.
    Tallahassee, FL
    I knew it got lower but all the way to 5? that isnt the comp lockout is it?
    I figure the OP wouldnt want to change to a IAQ anyway....
    Thats aux lock out.
    Tallahassee, FL
    Impressive.....I know we differ on quite how cold a HP will still perform....just curious...whats your recommended lockout temp? Since it rarely gets much below freezing here i set up older 10 seers to 40 and newer units to 35. I know you have to take customers comfort in mind...but im sure you have a recommendation thats a good balance of comfort/economy.
    5 before thermal balance point.
    If thermal balance point is 30, then aux lock out should be set to 35.
    Tallahassee, FL
    How do you know the balance point of every matchup? Is there a formula?
    You need the spec/tech guide for the unit. And the load calc of the house.
    Then do a plot on graph paper.
    If your installing a new thermostat for a customer. And you didn't put the system in.
    Then you have to guess. or do a load calc(never meet a customer that would pay for a load calc, just to have a thermostat set up right).
    How good your are at guessing determines if you get a call back for not enough heat later.
    And if it saves them a lot of money.
    Tallahassee, FL
    Ok I think I understand...Basically we compare the Btu/hr of the HP at a OD temp
    then compare how much the home is letting in
    Balance point is where two lines intersect?
    Yes, thats it.
    And the graph is just done on a paper like this:
