Results 1 to 13 of 14
    Jan 2010
    5T units/tax credit
    Are 5T units that meet the federal tax credit requirements really that rare? I've talked to two contractors. The first said he could get me a Performance 17 and that was about it. The second said he had literally nothing in 5T.
    Are they just trying to sell only what they have in stock, or are qualifying 5T units that rare?
    They are rare.
    The larger the size. The harder it is to make it efficient enough to meet the standard.
    Tallahassee, FL
    Beenthere correct me if im wrong Amana should have a Cased Coil and MBE blower matchup that does qualify. I will research ARI Number. If i get a response.
    It may. Some manufacturers have 5 ton heat pumps that will qualify.
    I don't know who all though.
    Not sure if any A/cs do though.
    Tallahassee, FL
    Guess I need to know which it is. The cased coil and modular blower setup are heat pumps too.
    Tallahassee, FL
    Heres a Heat Pump Amana
    Jan 2010
    Thanks guys. I'm fairly new to this.. I live in Phoenix, would a heat pump be a reasonable and economic option, or are they considerably more expensive?
    Anybody know of any other options besides the Performance 17 that would qualify at 5T?
    EDIT: My house is just under 2200 square feet, built in 1997 so probably reasonable insulation. For a typical Phoenix cookie-cutter house, 2 stories, is it likely I require a 5T or would a 4T be adequate? Nobody that's come out has really done a real calculation, they just asked square feet and existing (old, crappy) 5T unit that's out there now. In particular, I'm interested in whether the Nordyne Iq drive 4T unit would be suitable.
    Need a load calc done to know what size you need.
    You can do your own HVAC Calc if you want.
    Its worth the 49 dollar fee.
    Dec 2001
    Ocean Pines, MD
    I'd look into two separate systems. Not saying that it can be done, but I'd still look at the possibilities. More efficiency, comfort and Tax Credit models available.
    God's country
    goodman has a 5 ton too.....might be a little more affordable than amana if u are on a tight budget(same company as amana).....Trane has no offer in the 5 ton heat pump,we can do u a gas furnace(120k btu,95%,5 ton drive) and get u the credit......
    Talking 5 Ton system
    Quote Originally Posted by troutfly View Post
    I don't think he's on a tight budget if he's looking at an IQ drive, but 5 tons for 2200 sq. ft seems kinda high, maybe not. As others have said, he needs to get an accurate load calc. Also as Stamos suggested, two units might be worth looking into. Don't get in a big hurry, look at all your options and find a good contractor. Good luck. ibis1
    Nov 2000
    Eastern PA
    Best to go with a heat pump. They are easier to qualify for tax credits and enhance any heating system.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Tallahassee, FL
    Yes look into that Amana and Goodman system. They are both the same company. The Amana will be a little nicer unit (appearance, construction, sound level) but pretty much functionally the same. In a Dry Arizona summer I would think that since latent heat (moisture...humidity) is not a big issue you could go with a 4 ton outdoor unit and move 5tons of air with the indoor unit and still remove plenty of sensible heat. Anyone else agree?
