Results 1 to 12 of 12
Thread: Freezing up problem
03-02-2004, 10:27 AM #1
- Jan 2001
- 171
I'm having problem on a Bev-Air reach-in under the counter beer cooler. Installed a new thermostat that Techs at Bev-Air said it took. But the number one setting is allready at 32° Is this a refrigerant problems or did they send me the wrong cold control. Thermostat cap gets inserted in a well.
03-02-2004, 10:41 AM #2
If your unit is low on gas or the condenser real dirty, the coil can freeze as the part of the coil the stat is in doesn't get cold and the thing keeps running freezing up the rest of the coil. The stat probably has a constant cut in, above freezing.
Hey cockroach, don't bug me! ©
www.AskTheDiceman.com
www.TheColdConspiracy.com
www.Pennwood-HVAC.Com
Bring Em Home....
03-02-2004, 12:59 PM #3
- Jan 2001
- 171
Hi Dice
I installed this cold control about 3 mo. ago and he just call today and said his beer is freezing up. I don't know if the evaporator is freezing or not, but I had trouble setting the control when I install the new one. I didn't throw my gauges on because I hate working in a smoked filled bar full of drunks. Had bad experiance cigarett landed in my butt crack about 10 years ago. I don't like bar room work.
03-02-2004, 02:58 PM #4Sorry, but I laughed my a*s off when I read about the cigarette!!!Originally posted by Danal
Hi Dice
You might also want to take a look at the amount of product and placement in the box (interferes with air flow) and make sure the doors are closing tightly. This can also cause the product nearest to the evaporator to freeze. And tell him if he didn't sell that watered down lite crap, it wouldn't freeze as fast. Depending on his clientele, he might be selling them the weak stuff to keep them sober enough that they don't flip cigarettes at the repairman's crack.
03-02-2004, 03:19 PM #5
Put on your asbestos coveralls and go back and check that POS out. I hate bars full of drunks too, unless I happen to be one of them.
Bring Em Home....
05-15-2004, 02:24 AM #6
- May 2004
- 29
make sure that the tstat bulb is in the right place and pushed in far enough. if it is then replace with ranco A12701
05-15-2004, 03:25 AM #7
- Feb 2003
- 1,165
If you installed a new stat 3 months ago and the problem just occurred it could be that the control has been monkeyed with and been turned lower or as Dice says just a dirty condenser. Sure makes ya wonder? Whats tougher to fix a supermarket rack or an under counter reachin with your exposed butt crack! Give me the rack anyday as I dont have to listen to what the "stool" pigeons say. Asbestos not required.
Watts New, Ohm My, I been Electrically Commutated. Are U2.
05-15-2004, 10:26 AM #8
Have you seen my revolting policy?
Ragheads are cheap, and have a tendency to not pay after receiving service. Fact.Originally posted by Danal
I am not politically correct, in fact, I'm often just plain not correct. Fact.
I don't care what others think about my attitude. I am discriminatory. I know and accept that. Big fact.
Here's a little list of businesses that I never conduct business with:
- Asian groceries.
- Asian restaurants.
- Middle Eastern groceries.(Raghead, dothead...)
- Middle Eastern restaurants.
- Mediterranean restaurants.
- Restaurants, of any variety.
- Establishments that sell alcoholic beverages.
- Establishments involved in gambling, legal or otherwise.
- Any establishment that sells gasoline, in conjunction with any of the above listed items.
- Above list subject to be added to in the future. No deletions will be made.
That's the way it is, I don't need to explain my reasons, but let me state here that my biggest tax problem for the last few years was having no uncollected debt to write off. I like it that way.
I got scolded just yesterday!
05-15-2004, 10:27 AM #9
BTW,
Sounds like they sent you the wrong stat.
05-15-2004, 02:56 PM #10
- Oct 2003
- new orleans,la
- 147
Re: Have you seen my revolting policy?
- Asian groceries.
How about a strip club with full of nude girls, DAVE. - Middle Eastern groceries.(Raghead, dothead...)
koolrite837
05-15-2004, 03:16 PM #11
- Oct 2003
- new orleans,la
- 147
Man, I had to deal with 90 percent of DAVE unwanted jobs everyday.
It !s really suck
koolrite837
05-15-2004, 07:50 PM #12
BV, Better you than me.
