Results 14 to 24 of 24
    Skokie , IL near chicago
    regulator springs
    Quote Originally Posted by timebuilder View Post
    I would think that any spring would be fully compressed with the adjuster screwed all the way down. I could be wrong though.
    New one works great.
    the springs i was referring to are the different colored springs that you specify to be in that reg. when you buy it to match the inlet pressure and the cfh needed to match the firing rate of the unit attached to the reg. the reg was prob. bottomed out to get more pressure to the unit & the reg may not have had the right spring installed. check out the maxitrol website to download a spring chart for all their regs..........Jack
    Southeastern Pa
    Quote Originally Posted by rojacman View Post
    I'll have to download that chart for future reference.
    It seems counter-intuitive that the identity of a fully compressed spring could make a difference in the output of the regulator.
    I kept the thing, so now I'll have to grind off the rivets and open the thing up.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Talking springs for gas regulators
    if you will check out the various springs available you'll find they all have different colors for identity and they vary in their individual tension from very weak to very strong depending on how hard they have to push down on the diaphragm. no grinding needed , just remove the adjusting screw from the top of the reg & you'll see the spring is right under there............Jack
    Raleigh N.C.
    Belive it or not have actualy seen regulators under water on a roof "makin bathtub bubbles"
    Damn phosgene
    Southeastern Pa
    I'm unclear. My bad.
    I know where the spring lives and how it is replaced. What I don't know is the manner of failure of the old regulator, in that it would not passs more than a trickle of gas with with the spring screwed all the way down.
    Both of the values listed for this regulator cover the desired output pressure, so we shopuld be good. I did not have to bottom out on the adjustment to get the pressure I wanted.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    so i assume that no one ever pulled a permit when they installed that?
    If you can not do it right, Why even do it at all?
    Southeastern Pa
    Quote Originally Posted by luv2cruiserccl View Post
    It's an upscale strip mall installed about six years ago. Maybe 60 units.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    DuPage County, IL
    So, I get it all back together, and I'm ready for the burn-off. On the initial visit, the unit had fired, but not well. Due to the bad HX, it could not be operated long enough to fully delve into whatever problems might be present.
    I get out the Testo and find the gas pressure to the unit is not what it should be.
    I look at the regulator, and find the setting was screwed down ALL the way, in an effort to get more gas into the unit.
    Now, it has a nice new one. Not screwed down to the bottom, either.
    Attachment 69462
    Maybe these guys are a necessary part of the industry, to keep the rest of us working. It still bothers me, though.
    I thought vent limiters were for indoor use only. Shouldn't there be a goose neck on that regulator vent instead. Or better yet, Maxitrol now makes rubber regulator caps which around here, have greatly helped keep moisture from getting in and freezing up the regs
    Figman
    S.E. Pa
    Cool
    Quote Originally Posted by german 8'er View Post
    From Maxitrol:
    NOTE: Vent limiters are designed for use indoors and in
    spaces where limiting the amount of gas escapement due to
    diaphragm failure is critical. Vent limiters are not to be
    used outdoors if they are exposed to the environment.
    13A15 vent protector is available for outdoor use when vent
    protection is required.
    HTH,
    Hearthman
    Southeastern Pa
    Quote Originally Posted by hearthman View Post
    From Maxitrol:
    HTH,
    Hearthman
    Thanks for posting that excerpt. I saw that as well.
    This is out by route 1 and 202. I'm sure there was an appropriate inspection done when these units were piped in. At least, one would hope so.
    All of the other units for this strip mall are pretty much identical to this one.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    help
    been a while since i've been on this site. where do you find the link for the pic??
