Results 1 to 13 of 14
    Dec 2009
    Newbie T'stat Question
    I just replaced an old Honeywell thermostat with a new Honeywell RTH230B. I have hot water baseboard heat, no AC - a 2 wire installation. For some reason it works in heating mode but never shuts off when it reached the set point.
    Any idea what is wrong? Do I have the wires reversed? They are installed the same way they were on the last thermostat.
    Thanks in advance for the help.
    chicago
    Quote Originally Posted by Hydestone View Post
    How did you decide on that stat?
    Dec 2009
    I just needed a simple stat with 4 periods per day and 5-2 day setting. It was relatively cheap and same make as my old stat.
    chicago
    I would verify the new stat is the right stat.
    Dec 2009
    Its pretty generic and my system is quite simple...1 boiler, no ac, 4 zones, 4 pumps...on or off basically.
    chicago
    If you put your old stat on and your system still works, its safe to say it's your wiring or a bad stat. right? I can't think of anything else to say without getting into troubleshooting.
    Apr 2009
    Pan Handle, Fl
    There should be an help phone number in yhr back of your manual, they should be able to answer your questions and help you.
    Insanity: Doing the same thing over and over again expecting a different outcome!
    Dec 2009
    when I was wiring the new stat I did see a spark when I accidentally touched a screwdriver to the W terminal Do you think that could have anything to do with it?
    Dec 2009
    I switched the jumper on the inside and she works fine now. I will keep an eye on her to make sure.
    Are we still talking about a Tstat?
    Aug 2009
    East TN
    Why would you leave the power on when you are wiring something? That's just asking for problems.
    I know. It was a "short" cut.
    Lancaster PA
    Quote Originally Posted by Trog View Post
    No.
    He was getting ready to race, and only wanted to practice on a short circuit.
    north of 49
    There are other reasons besides your stat that will keep the system operating when the stat is satisfied. Best you get it looked at
