Results 1 to 13 of 20
Thread: fan shuts down
01-15-2010, 11:53 AM #1
- Jul 2007
- 79
fan shuts down
i have a 23 yr old bryant heater,when it cycles on and off the fan shuts down too,shouldnt the fan run constantly till it reaches the desired temp,how can i fix this problem,i thought it was suppose to work that way
01-15-2010, 12:01 PM #2
01-15-2010, 12:24 PM #3
- Jul 2007
- 79
the fan shuts down every time it cycles every 3 or 4 minutes the fan should continue till it reaches the temp setting,right
01-15-2010, 12:35 PM #4
Ok, I think I understand what you're saying now. The fan is short-cycling during a call for heat. Same answer though, you need to have it checked out by a qualified service tech. I could go over a couple of likely causes for that, but unless you're going to attemp a repair youself, that info won't be of much value to you, and unfortunately we can't provide DIY advice in this forum.
01-15-2010, 01:53 PM #5
- Jul 2007
- 79
can you tell me a couple of things that it could be,thanks
01-15-2010, 02:17 PM #6
I can only list two possible causes without providing DIY info. Those are plugged air filter and/or too many vents closed off. Have you checked the air filter? Do you have several vents closed off? The other items on the list would involve mechanical repair to the system, and because of that they would fall under the category of DIY, which again, is not allowed in this forum. HTH.
01-15-2010, 02:56 PM #7
- Jul 2007
- 79
ok thanks,its not either of those two
01-15-2010, 05:31 PM #8
- Dec 2007
- chicago
- 249
01-15-2010, 09:07 PM #9
- Jun 2006
- Omaha, Nebraska
- 766
What kind of stat are you using? If it's mechanical it could be the anticipator adjustment.
Has it always done this? New house? You said "heater". Is that electric or gas furnace, or heat pump?
01-15-2010, 09:22 PM #10
- Dec 2009
- 53
sounds like it's cycling on temp limit. Get a pro to find out why or if.
01-16-2010, 12:50 AM #11
Professional Member*
- Mar 2001
- 1,408
ANTICIPATOR
One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
01-16-2010, 08:49 AM #12
- Jul 2007
- 79
it has always done this
its a gas furnace,ive had 2 thermostats and its done them on both,the fan will run on on position,
01-16-2010, 09:34 AM #13
- Dec 2009
- 53
are you saying the funace shuts down after running a few min. and not reaching your thermostat setpoint, and then cycles back on a few min. later?
