Results 1 to 8 of 8
    Jan 2010
    Do I have enough air returns
    I have a two story house approx. 2300 square feet. I have a 5 ton single unit. One contractor told be a need another air return. Currently I have one air return that hold two 16x20x1 air filters. I buy the more expensive 3M filters because they are a little more sturdy. The cheaper one tend to fold in from the vacuum.
    How do I know how big the air return should be for a 5 ton unit?
    Oct 2006
    The Beach
    We use 200 sq. inches of return grill size per ton. With the proper size return ducts. And at least one return on each floor.
    Blue Fox
    Jan 2010
    So with a 5 ton unit I need 1000 square inches. What size should the return duct be for 1000 square inches?
    Rochester NY
    About 36% bigger than 640.
    You got yourself 3 gallons milk and only 2 jugs. System heat n cool ok? Then unit probably oversized. If not, ductwork probably undersized. Either way sounds like a mismatch.
    Jan 2010
    I live in the Houston area FYI... The system heats well, but sometimes in the summer it has a hard time keeping up. The unit is 5 tons for 2300 square feet.
    Agawam, Ma
    2-25x20x1 filters, and maybe try another pleated filter. The 3M can too restrictive.
    Atlanta GA area
    Quote Originally Posted by stone-cold99 View Post
    This would be a good start, but the extra return duct is a MUST! If the system cannot suck enough air, it cannot deliver enough air.
    I grew up in Houston, I know how brutal the summers can be. Get the system pumping enough air and you will feel better. While you are at it, have a qualified tech come out and clean/service your unit. Might find some details that will help it run more efficiently.
    GA-HVAC-Tech
    Apr 2006
    Houston, Texas
    & minimum duct on each should not be less than 16"
