Page 9 of 18 FirstFirst ... 2345678910111213141516 ... LastLast
Results 105 to 117 of 225
  1. #105
    May 2013
    Hi all--
    I need to change the IP address of my D-BACS; will the SetupMS3 software allow me to do that? If so, may I ask you to to send it to me as well, please?
  2. #106
    Jun 2007
    North Carolina
    Hello All, It sounds like many are in the same predicament that I am in! Could I get a copy of the SetupMS3 software?
    It would be greatly appreciated.
  3. #107
    Jul 2013
    I have to change the IP & Device instance on one of these gateways, can I get the software please. Thanks in advance.
  4. #108
    Jul 2013
    Can you email me the setup ms3software please
    Email Address Removed
    Last edited by Chris_Worthington; 09-01-2013 at 05:12 AM. Reason: Email Address Removed
  5. #109
    Jul 2013
    Dakin DBACsetup
    Quote Originally Posted by nickh View Post
    Glenn, How are ya? i will email it through!
    you wouldn't have an Alpine TukTuk licence would ya??
    Canm you email me the Daikin DBACset.exe a need to check unit addreses or how do i get it
    Would really apprecite it
    Kg4399
  6. #110
    Jun 2013
    NORTHERN
    me 3, the SetupMS3.exe or the SetupDBACS.exe
    em in profile
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
  7. #111
    Jun 2013
    NORTHERN
    Please send .
    about a reheat hot ggas coil in a pool conditioning Hydro-Temp, AR that also performs 100% HW in reclaim on-demand when not in recovering heat from cooling, with the BACnet module and related control programmin.
    Factory set up changned once in 6 years running
    but
    with Pool Water heating and Dom HW Priorities in/out of heat-Recovery in a series with calls for DeHumidification and Cooling, when not heating the pool,
    I would think there may be better controlling available, since learning new options has been interesting enough.
    Please le'me know how to get
    SetupMS3.exe or the SetupDBACS.exe and any commentary would be appreciated
  8. #112
    Jul 2013
    Hi
    Email is now in profile and the setupdbacs.exe would be great.
  9. #113
    Feb 2013
    I was hoping someone could email me a copy of the Daikin software to setup their D-BACS. I need to change the port number and I'm assuming it has a default IP which I will need to change. Thank you in advance.
  10. #114
    Oct 2005
    I'd really appreciate getting the setup software also, email Email Address Removed
    Last edited by Chris_Worthington; 09-01-2013 at 05:13 AM. Reason: Email Address Removed
  11. #115
    Nov 2011
    Earth
    El Presidente,
    Could I please get a copy of the MS3 software too, I am trying to configure a Daikin Gateway, and I need to set a custom static IP, not sure if there is any other way to do so?
    Quote Originally Posted by El Presidente View Post
    threefiddy, check your mail.
    Pres
  12. #116
    Version I have is 6.201. Not sure if that is even current anymore. Haven't used it since 2011. Who wants it?!
    Pres
  13. #117
    Hampton Roads, Virginia
    Pres
    Yes please, email in profile.
    Thanks.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
